rBennerZ Posted February 16, 2022 Share Posted February 16, 2022 Noticed that my left rear indicator has stopped working, all others still works and comes up on dash, so can’t be the relay right? I have bought new indicators to replace the (suspected) blown one but haven’t got round to installing. But if that fails, what could be the issue? Thankyou Quote Link to comment Share on other sites More sharing options...
TimR Posted February 16, 2022 Share Posted February 16, 2022 Bulb ? Quote Link to comment Share on other sites More sharing options...
Old-codger Posted February 16, 2022 Share Posted February 16, 2022 As TimR said check the bulb or does it have LEDs. Does the left indicator flash at a faster rate now than the right indicator. Check the wiring from indicator to all connections and look for breaks or chaffing. If possible swap right indicator on to left wiring to see if it the works that will or not, then you know if fault is indicator or not. Quote Link to comment Share on other sites More sharing options...
rBennerZ Posted February 16, 2022 Author Share Posted February 16, 2022 It’s led, and it blinks, the same normal rate on the right, will try mess with it very soon Quote Link to comment Share on other sites More sharing options...
rBennerZ Posted February 16, 2022 Author Share Posted February 16, 2022 (And left front at same rate) Quote Link to comment Share on other sites More sharing options...
