2 hours ago, Gerontious said:
Now you’ll have to do what normal people do . Use a toothbrush!!
Nope, new one ordered with next day delivery (am) almost Β£140. Cheaper than screwfix.Β
Β
Vowed never ever ever to be without one ever again πŸ˜‚Β
3 hours ago, Bender said:
The grinder is dead, its had a hard life but it died at a most inopportune time as is always the fecking case
Β
Similar issue earlier in the year when I was mixing up some floor levelling compound and my drill died mid mix, smoke sparks then nothing perfect timing πŸ˜‚
  • Sad 1
you should have borrowed a whisk from the kitchen. I’m almost embarrassed that I need to point out the obvious!!!
  • Haha 1
And the whisker (wife) she'd have been made up πŸ˜‚
*hides wallet.
Β
Ive not been so paranoid since I was sneaked out of the back of Manchester crown court and ferried to an undisclosed location - aka stockport railway station. those were the days. when life was occasionally exciting and nobody cared about whether you owned a torque wrench or not.
1 hour ago, Ian Frog said:
Hi @BenderΒ is that another Milwaukee ?
Looks a lot better than their previous model.
Cheers
Ian
Yup, it's the slim version and takes 125mm discs with the gaurd on, not that it will be on for long, quick fit disk holding nut thing, thought I would try slim one as it helps getting into awkward places, which accounts for most of its positions πŸ˜‚, original is still available and cheaper.
Β
Hopefully lasts as long as first one.Β
Γ—
Γ—
