Brake disks
husoi
1 hour ago, megaross said:
Fair enough, be a job for crimp your own then I imagine.
Worth keeping on the todo list mind
The hoses will definitely be replaced.
Not on this month budget.
Need to recover the finances before spending anymore on it.
Unfortunately, I was born handsome instead of rich😄😄
  • Haha 4
Knowing how much you guys love pics...
front disks still to be delivered. Hopefully early next week. :thumb:
plenty of time for thorough and complete clean of all components.
by the way. Venhill doesn't have brake lines for ST1300.
best price for good quality still at £600 mark 🥺🥺
  • Like 4
  • Thanks 1
 Venhill do custom lines from memory?  if you let them know the lengths, if thats cheaper i wouldnt know.
freebies always make me smile!
when i order contact lenses which is rarely, i always get a small bag of haribos, then its entertainment of fight night, of which of my family wins it 😄.
Edited by RideWithStyles
  • Haha 1
Love new parts, love freebies more.
Used to be into computers years ago and one of the parts suppliers used to send 10p bags of haribo with the order. It was the best.
I mean it's a 10p bag of sweets but I have child brain, see them and go "ooh sweeties!"
The amount of lanyards, pens and mugs I've had from dealers over the years for free, never even bought through a dealer.
Not to mention the amount of White Dalton neck tubes I've got from the stall at bike events.
And the handful of pens I nick from the MOT place every year that keeps me in stationary for work.
Today's job.
Cleaning all the parts.
A good wash on the wheels
Then cleaned the calipers
And most parts
Tomorrow will be cleaning all the banjos and fit the rear disk. Then assemble rear wheel.
  • Like 3
Hi @husoi, is it a Optical illusion, but those piston look a tad on the long side, especially the far right!!
And I know you haven't started fitting them yet, but still look a tad long??
Your cleaned up wheels look brand new 😍
The pistons are all exactly the same size as old ones.
Will double check if they actually go in that calliper or not
1 minute ago, janinej said:
I always knew what a brake disc was but now I know the bit that makes the brakes go is a caliper?  Shout at me if I'm being thick
JJ
The calliper holds the pads (not in the pics) inside the calliper you have the pistons which will press the pads against the disk making the bike slowdown
Hi @husoi, HEL do a kit for the ST1300, and if you know anyone who go's to the BSB meetings, get them to check out the HEL stand, at Cadwell the other year I brought 2 set's of lines for the VFR's,
Can't remember how much they were then for each set, but got both set's for around £530, making a whopping saving! Set now is £400 + £40 for Clutch line.
Ended up flogging one set on eBay. 👍
But if not in rush for lines see next year if you can get a price from stand.
  • Thanks 1
Found out how to get a parcel delivered quickly.
You just need to be out of the house and courier will deliver it that exact date 🙄🙄🙄
  • Haha 6
Rear wheel fitted
IMG20231104114611.thumb.jpg.0fd5fbd19d743faf86bb0c972139c0da.jpg unfortunately front disks bolts are the wrong ones and wemoto will only send them on Monday 🙄🙄
Fixed exhaust with new shiny clamps.
These have to wait...
  • Like 2
Getting there 🙂🙂
Both front disks in place, wheel back in.
Tomorrow the 3hrs bleeding the callipers.
Each have 2 bleeders and have to be done together. Several times each calliper untill no air is in the system.
IMG20231108191912.thumb.jpg.5c8508d5487368d3d9af20536c9a08b4.jpgIMG20231108191905.thumb.jpg.524bec4adf1861adc24610d5ebcb4a24.jpg
  • Sad 1
All fitted back and all fluid replaced/bleed.
Now rear brake is stuck 😡
Youtube is saying probably cause the secondary front master cylinder maybe needing servicing.
Some guy replaced the balancing valve.
From memory the secondary cylinder was working properly.
So, either the balancing valve (a pain to replace) or need to rebuild the rear master.
While at it, maybe better to bite the bullet and get the 139 hoses and replace the whole lot.
Service the rear master, service the balancing valve.
costs are creeping up...
  • Sad 1
