Mattg224 Posted January 8 Share Posted January 8 (edited) Hi All, I hope you can help me out. My SIL (Sister In Laws) Lexmoto Apollo 125 Euro 5 [CL125T-E5], has an indicator issue as in, they flash for a microsecond on both the dash and the exterior of the bike each time the switch is activated. So we know the fuse is good, the bulbs are good etc, the bike is completely standard, dash lights up as it should all other lights work correctly. So I'm edging on the side of the relay being FUBAR. Now the issue I've got is where the flip is located as I can't seem to find any information for it on Google, or any online photos/videos etc. Also, this is the only mode of transport she has access to and is understandably worried about riding it without functional indicators, we have been on to the dealer she bought it from as it is less than 2 years old, but they want to charge her an arm and a leg to even look at it, and last time they had it in for its running in service they somehow managed to "Forgot" to reconnect the speedo drive cable. I won't mention names here as I don't want to open up the whole can of worms. Many thanks for any help anyone can provide. Picture added for illustration purposes. Matt - Edited January 8 by Mattg224 Quote Link to comment Share on other sites More sharing options...
Nick the wanderer Posted January 9 Share Posted January 9 Hi , Search lexmoto Apollo manual. Chinesemotorcyclepartsonline.co.uk has pictures and prices. Quote Link to comment Share on other sites More sharing options...
RideWithStyles Posted January 10 Share Posted January 10 Hi. This includes the Yadea and Voge range, as well as Lexmoto. All of our Euro 5 models now benefit from a 2-year parts & labour warranty, even the 50cc range! Every single one also comes with a transferable warranty, meaning that it now follows the bike onto subsequent owners, rather than just its first.12 Jul 2021 you should, name and shame its the only way they sort their shite out. normally the relys are near the fuses and ecu as they thats where space is. If you give pitstop in hull for example a ring, they might know if a different model has the same part but its not generally listed as such. other possibilities to check are if there is corroding in the switches or connectors of the loom. The other is if they damaged the pins being rough with it while they looked at it? why forget about speedo drive cable? What else have they done to it? Quote Link to comment Share on other sites More sharing options...
Guest Posted January 10 Share Posted January 10 Mostly the relays are under the seat were your backside is, or behind the plastic on the left side Quote Link to comment Share on other sites More sharing options...
