Hairsy Posted April 22 Author Posted April 22 I'll start by saying I'm not an expert. Based on my many hours of research though, the most common view seems to be that an avoidance of hyper-extension of the neck is something that we can benefit from. But that's extreme movement of the neck. The hump on race suits has this effect (even though it's primarily there for aerodynamics). Where there's shoulder, chest and high back coverage on an airbag, that can also help. I read one article (I thin it was by a surgeon but can't find it again) that said that the most extreme neck damage may come from the head coming forward, not backward or to the side. However, too much constraint around the neck can be detrimental and it would take only a small amount of 'excess' airbag around the helmet to cause the helmet strap to tighten and introduce issues of its own. Different airbags provide different levels of coverage, both up and down the torso. Torsos are different. Different helmets will be affected by different amounts by airbags. My suspicion (note that this is my opinion only) is that all of these differences are why no-one is claiming that they've managed to design the perfect airbag for avoiding helmet deflection - simply because there's no one 'perfect'. Depends on the person and the accident. As an aside, when I was into paragliding, there were 3 main designs of helmet. They were very different. They were all 'best' for a specific type of accident. The same may be true of airbags - choose your preferred type of accident and then someone can tell you the best airbag for you. PLUS the convenience factor - if you're rubbish at keeping things charged then you should only be looking at tethered systems because your electronic system won't work. If you're likely to forgot to fix a tether then don't look at tethered systems. I didn't come across any research that suggested that internal or external wearing of airbags makes a difference. In practice, an airbag deployment is so violent that any clothing will conform to the shape of the airbag below it. This is why its critically important to have enough space under your garments - one piece suits or zipped two piece suits need to be treated and assessed with caution and leather should have stretch panels. What I did come across regarding the internal/external question was that abrasion resistance is a potential issue with externally worn airbags. A lot of abrasion can damage the airbag and be catastrophic. On track, most big impact injuries occur as the first event in an accident and so abrasion resistance may be less of an issue because the impact has happened before the abrasion sets in (although there's still tyre barriers etc to hit after a slide). For road use though, the main impact might be with street furniture / roundabouts / trees / etc which can happen after the clothing has been subject to a lot of abrasion during an extended slide. There's also a secondary benefit with airbags worn under jackets in that they're likely to be reusable after a slide. I hope that's helpful and I'll repeat that I'm not an expert. Please don't make any decisions based on what I've concluded - do your own research. 1 Quote
RideWithStyles Posted April 22 Posted April 22 The jacket for underneath airbags have been designed to have burst strength seams and excess material folded to allow space for the airbag to expand so the air bag isn’t restricted by the jacket. If not then there is three possible out comes for failure, the bladders pop, the bladders fail to expand properly or damages yourself… if you don’t buy a designed with one you have to go up a size or so but as people will know they aint all perfect to your biometrics, but if its boarder line now(tight neck, chest, arms etc) and you decide to put an extra layer or a heated vest underneath (most have edges for the connectors) you risk something going wrong. Quote
Hairsy Posted April 24 Author Posted April 24 Airbag has arrived and seems fine - I guess there's not much to say about them until you need them. But it synced up with it's app, installed itself some new firmware and then just did what it should. It fits fine under my winter textiles but not my summer mesh jacket - as I suspected. I'll keep the current jacket for use when I'm not using the airbag - that will be infrequent but I know that if I'm popping out 5 minutes down the road then I'm not conscientious enough to put the airbag on every time. I'm off to Sportsbikeshop tomorrow to try on some alternative mesh jackets. My preference is to go for a larger version of my current mesh jacket (because I really like it, has a great removable wind & waterproof liner and is great value). However, if that doesn't work for me then I may bite the bullet and get one of the Alpinestars made-for-airbag leather vented jackets. 2 Quote
veracocha Posted April 30 Posted April 30 My Helite was deployed today albeit at a stationary drop. Side-stand wasn't properly down and gravity did the rest. That vest inflated well before I hit the deck and boy did it cosset me on the fall. My initial reaction was please deflate a bit quicker so I can asses the damage to the bike but it was a good three-4 minutes before I could pick the bike up (no damage at all). Here's the biggest lesson I learnt today (I already know about the stand). It's worthless having a spare canister with you for such an event if you haven't got a piggin allen key to wind the plunger back out. The trip over the Applecross Pass wasn't as enjoyable as the many times I have done it in recent years. Luckily a garage had a set which got my mind-set back on the journey through Scotland. Bravo Helite. 3 Quote
bonio Posted April 30 Posted April 30 27 minutes ago, veracocha said: It's worthless having a spare canister with you for such an event if you haven't got a piggin allen key to wind the plunger back out. Oo. Ta for that. This fact had escaped my small brain. 1 Quote
Evotion Posted May 6 Posted May 6 They should be mandatory like seatbelts on a car. Insuit and outer, both are better than nothing. Case in point, I had a highside at Donnington in the damp and so did my mate. He broke his collar bone and I was fine thanks to the deployment of my Helite jacket. Certainly, only get one that puffs up around the neck too. Ah, here is the video! I also talk more about the tech itself. 3 Quote
