Stu Posted December 16, 2008 Posted December 16, 2008 well time to get the bike ready for the summer first job swap my EU headlight for the UK one i won on ebay 5 min job next on the list adjust valve clearances, set throttle position sensor, balance throttle bodies, get it set up on a dyno, check steering head bearings, new oil in steering damper (or new one) save for new rear shock and fit that, then save for new for springs and fit them and hopefully re valve forks but that could run into the summer, all new wheel bearings plus a few extra little things along the way started off like this currently like this for now will post more pics as time goes on Quote
Guest Posted December 17, 2008 Posted December 17, 2008 Still think it looks better in black But that sounds like a lot of work? How come you have to do all that? Quote
PhatDad Posted December 17, 2008 Posted December 17, 2008 Because he can. Oh and Stu, is that your garage or just some hangar your rent out to store your bike in? It's mahoosive!!! Quote
Stu Posted December 17, 2008 Author Posted December 17, 2008 as phatdad said cos i can also i like to know my bikes are in tip top form phatdad its a lock up me and my dad and a few others rent Quote
Guest Posted December 17, 2008 Posted December 17, 2008 ohh, so it doesn't need it? Your just improving it? Do you ever take it to the tracks? Quote
Stu Posted December 17, 2008 Author Posted December 17, 2008 it needs some stuff doing like adjust valve clearances but when you do that you have to balance throttle bodies and before you do that you have to set throttle position sensor then it needs seting up on a dyno, also needs new oil in steering damper (or new one) i want a new rear shock and new fork springs and all new wheel bearingsnot done any track days on it YET Quote
craig Posted December 18, 2008 Posted December 18, 2008 adjust valve clearances is that a hard job stu...........hint hint Quote
Stu Posted December 18, 2008 Author Posted December 18, 2008 Come and do my bloody electrics i will have a look if your not in no rush for the bike ? not sure when i have time off Quote
Stu Posted December 18, 2008 Author Posted December 18, 2008 adjust valve clearances is that a hard job stu...........hint hint depends on the bike Quote
techno Posted December 18, 2008 Posted December 18, 2008 Am gonna try the jump lead thing, if that has no results it will be garaged till Feb!!So I can get some cash, push the insurance back and have it mot'd at the same time! Quote
Stu Posted December 19, 2008 Author Posted December 19, 2008 well if thats the case im sure i could pop down between now and feb and take a look for you no promises though im not a sparky Quote
Stu Posted February 10, 2009 Author Posted February 10, 2009 work continues took my bloody time didnt i pulled a few more things off the bike then a few more and more currently looking like this a few little electrical gremlins sorted valve clearences checked cams out to measure shims and shims ordered there was only 2 that was out of spec and that was only by .03mm cams awaiting removal rear cam out with bucket and shim removed bucket and shim to be continued Quote
Guest Posted February 10, 2009 Posted February 10, 2009 lol I have no idea what any of that stuff is! Wish I did.. Quote
Stu Posted February 10, 2009 Author Posted February 10, 2009 lol I have no idea what any of that stuff is! Wish I did.. and i do ? Quote
Guest philgale Posted February 10, 2009 Posted February 10, 2009 taking it apart is the easy part........putting it back together is the hard bit good luck Quote
Stu Posted February 10, 2009 Author Posted February 10, 2009 putting it together is the easy part mate you just glue the bits that you had to grind off Quote
Guest philgale Posted February 10, 2009 Posted February 10, 2009 just give it someone else to put back together for you Quote
Stu Posted February 10, 2009 Author Posted February 10, 2009 no thanks i like to know things are right Quote
chrisgatguis Posted February 11, 2009 Posted February 11, 2009 Yeah it must be great being able to dismantle the whole bike like that!Keep the pics coming they're well cool Quote
Guest philgale Posted February 11, 2009 Posted February 11, 2009 oh stu, when your thinking of sticking it on a dyno let me know. one of my mates runs a dyno centre and ill have a word and see how much...unless you know someone nearer you who is cheap... Quote
Stu Posted February 12, 2009 Author Posted February 12, 2009 had a quote for £120 mate all set up Quote
cossie916 Posted February 12, 2009 Posted February 12, 2009 putting it together is the easy part mate you just glue the bits that you had to grind off Yep. Its starting it that is the hard bit! Good luck, going well so far! Let me know when you are doing some track time as I want to go again this year, its been a while! Quote
craig Posted February 12, 2009 Posted February 12, 2009 adjust valve clearances is that a hard job stu...........hint hint depends on the bike cbr 600 rr Quote
techno Posted February 12, 2009 Posted February 12, 2009 Should have bought a decent bike then you wouldnt have to do any of that shit! Quote
