sparkeh9 Posted December 14, 2010 Share Posted December 14, 2010 Im thinking about getting a slip-on exhaust for my bike, and replacing it with the stock one, the can comes with the bit of pipe (forgive my ignorance) that connects to the down pipes.So what's involved? Is it major surgery? Quote Link to comment Share on other sites More sharing options...
andyc Posted December 14, 2010 Share Posted December 14, 2010 Bit of pipe = link pipe.Simply a case of remove the bolts securing the old can and link pipe and replacing with the new one, make sure new can isn't rubbing on the swingarm, and link pipe doesn't interferre with rear brake operation. You'll need spanners and poss allen keys, shouldn't take long (30 mins) , you may need a new seal that joints the link pipe to headers (about a tenner if memory serves) or make good with firegum . Quote Link to comment Share on other sites More sharing options...
sparkeh9 Posted December 14, 2010 Author Share Posted December 14, 2010 Just read that aftermarket exhausts may increase power output, but obviously im on a restricted license, so if it's true I cant .But I was thinking, will it actually increase the power output, as I've restricted my bike at the carbs so air is bottlenecked at that point. Anyone have any thoughts? Quote Link to comment Share on other sites More sharing options...
Guest Posted December 14, 2010 Share Posted December 14, 2010 I may be completely wrong as I know next to nothing about the mechanics of bikes but; does a slip on can not affect anything? I though only a full aftermarket exhaust system would increase power, I just thought a slip on can was for sound and looks.But I could be wrong :/ Quote Link to comment Share on other sites More sharing options...
Bob R1 Posted December 14, 2010 Share Posted December 14, 2010 It wont make much differance ,unless you fit a full system and a free flowing airfilter,but it should be abit noisier, Quote Link to comment Share on other sites More sharing options...
Decor58 Posted December 14, 2010 Share Posted December 14, 2010 At best a decent exhaust will offer 4-5 bhp extra, it's likely to be a lot loss for a mid-range silencer 3 tops most likely 1-2bhp, so personally I'd say just go for it with respect to the power, no one is going to question it.As to fitting it, it's just take off the old one, maybe 3 bolts, make sure the ends of pipes are clean, add a little exhaust sealant, put together again (same 3 bolts you took off) and wipe excess paste off.Shouldn't take more than 20-30minsThough will then have to wait for the past to dry, this can be done by leaving the bike to idle, until exhaust gets to operating temperature + 5-10mins extra. Don't rev it during this time.♦Put a new can on mine not long ago, was really easy. Quote Link to comment Share on other sites More sharing options...
