wannars125 Posted January 23, 2011 Share Posted January 23, 2011 Hi,Can anyone clarify if the weight limit on hard luggage is contents or contents+case?If it is contents + case, how likely is it to go flying off down the motorway if it is slightly over?!? I'm looking at the givi/kappa monokey products. Quote Link to comment Share on other sites More sharing options...
Guest Posted January 23, 2011 Share Posted January 23, 2011 I think the racking has a limit Anand, then the luggage has a capacity limit .. or something like that Quote Link to comment Share on other sites More sharing options...
wannars125 Posted January 23, 2011 Author Share Posted January 23, 2011 Another limit?!?!? :sIt's just getting more confusing! Quote Link to comment Share on other sites More sharing options...
jacol Posted January 23, 2011 Share Posted January 23, 2011 You should be fine if you put just spare pair of gloves in it Quote Link to comment Share on other sites More sharing options...
Guest Posted January 23, 2011 Share Posted January 23, 2011 Lol Anand, check the racking, it probably says something like 12kgs, the luggage probably says something like 7kg capacityDon't quote me! Quote Link to comment Share on other sites More sharing options...
bullet5 Posted January 23, 2011 Share Posted January 23, 2011 The numbers they give are guides, but not to be taken too seriously. For example, my rear rentec rack on bandit says dont put more than 7kg onit, well i've used the thing to lift the bike up at the rear end to move it around (when i took off my wheel, and swinger for working on) so must ahve had what? ... 110kg on it? The thing to be more worried about is the actuall topbox, make sure whatever you put in it wont smash against the sides (possibly causing a crack to appear) But yet again, I wouldn't see anything wrong with carrying a 12kg chain, and lots of extras in the box. -- Make sure if you do get one, that you harden up the rear shock just a smidgen, as having a 12kg chain in a top box, would be amost equivalent to you putting on... say 20-30kg? Quote Link to comment Share on other sites More sharing options...
TC Posted January 23, 2011 Share Posted January 23, 2011 On the Givi site it tells you what each box can carry (recomended) MonoKEY are stronger carry more weight and are for MotorbikesMonoLOCK are lighter and for scootershttp://www.givi.co.uk/cases/ Quote Link to comment Share on other sites More sharing options...
wannars125 Posted January 24, 2011 Author Share Posted January 24, 2011 TC, I got confused after looking at another site. I assumed from the givi site that it would be that the contents were the 10Kg but then another site said the case+contents made up the allowance. The Hein Gericke shop near me were useless too. I think I'm going to have to pay a visit to my normal Hein Gericke people. Just don't want to spend all that money and get it wrong. Quote Link to comment Share on other sites More sharing options...
TC Posted January 24, 2011 Share Posted January 24, 2011 Wanners. Click on the link, select the case Mono KEY/LOCK chose your case and it will tell you the size and what weight it can carry.IE The V46 monoKEY only has a 46 litre capacity but can carry upto 10kgThe E470 monoLOCK has a 47 Litre capacity but can only carry up to 3 kgThats the case (no pun) with Givi Quote Link to comment Share on other sites More sharing options...
Roadtorque Posted January 24, 2011 Share Posted January 24, 2011 Givi V35 = 10kg per pannier,, two panniers & top box see's me ok for two weeks touring, on the road you don't know they're there Quote Link to comment Share on other sites More sharing options...
duane69 Posted January 24, 2011 Share Posted January 24, 2011 my rack has a 6kg limit but the box is 10kg limitand my arse has a 12stone limit but I'm 16 stone lolsorry about that I've been on the vodka again my doc told me to drink more fluids Quote Link to comment Share on other sites More sharing options...
Roadtorque Posted January 25, 2011 Share Posted January 25, 2011 my rack has a 6kg limit but the box is 10kg limitand my arse has a 12stone limit but I'm 16 stone lolsorry about that I've been on the vodka again my doc told me to drink more fluids So that's the diet out the window then Duane Quote Link to comment Share on other sites More sharing options...
wannars125 Posted January 26, 2011 Author Share Posted January 26, 2011 Cheers RT good to know the amount of stuff you can fit in! Quote Link to comment Share on other sites More sharing options...
wannars125 Posted February 12, 2011 Author Share Posted February 12, 2011 Just thought I'd update. I paid a trip to the local Suzuki dealer. They've said that the weight that Givi give (10Kg) is the weight of the box plus contents which only leaves about 5Kg....He did add that it was up to the individual if they wanted to carry more but it was at their own risk... Quote Link to comment Share on other sites More sharing options...
