Boothy Posted January 22, 2012 Share Posted January 22, 2012 Right so I was coming back down the motorway on Friday night and I was being flashed by every lorry that I went past. I pulled over to have a look at what I could see. Both of my rear lights were not working . Both brake lights are working even though they are duel filament bulbs. Looked at the fuse box and none of the fuses have blown and also replaced both bulbs even though the filaments looked intact. Run out of ideas now, anybody? Quote Link to comment Share on other sites More sharing options...
davefly76 Posted January 22, 2012 Share Posted January 22, 2012 Switch, or wiring from the switch? Quote Link to comment Share on other sites More sharing options...
Tango Posted January 22, 2012 Share Posted January 22, 2012 Check the connectors going to the rear lights.....and also make sure there is a good ground connection to them.....other than that it's gonna be wiring or the like.... Quote Link to comment Share on other sites More sharing options...
Stu Posted January 22, 2012 Share Posted January 22, 2012 Get a multimeter and work from the rear to the front Turn the lights on and check if your getting power for the lights if not work your way to the front till you find why not I would say its not the earth as the break light should use the same one and they work fine but still worth a look to make sure its not got its own Quote Link to comment Share on other sites More sharing options...
mealexme Posted January 22, 2012 Share Posted January 22, 2012 Check the connectors going to the rear lights.....and also make sure there is a good ground connection to them.....other than that it's gonna be wiring or the like.... +1. Connectors would be what I would do next. Apart from that I wouldn't have a clue lol Quote Link to comment Share on other sites More sharing options...
cruz Posted January 23, 2012 Share Posted January 23, 2012 Had the same issue with the Divvi last year. found a break in the live feed for the lights. Seems the brake uses different a feed. Quote Link to comment Share on other sites More sharing options...
