mattycoops43 Posted April 28, 2012 Share Posted April 28, 2012 Hi thereFitted new bars today, standard 7/8" fitting. The indicator switch gear was loose on the old bars, and now they are both loose, as in, will turn if you push them.In the past I have tried using insulating tape to take up the slack but it's too soft for the switchgear to clamp on, is there something I can use that will actually work?ThanksMatt Quote Link to comment Share on other sites More sharing options...
Tango Posted April 28, 2012 Share Posted April 28, 2012 Maybe a bit of bicycle inner tube cut down to size? Quote Link to comment Share on other sites More sharing options...
megawatt Posted April 28, 2012 Share Posted April 28, 2012 I use a folded piece of wet n dry. Quote Link to comment Share on other sites More sharing options...
mattycoops43 Posted April 28, 2012 Author Share Posted April 28, 2012 OOO Inner tube! I got one of those knocking around! Thanks for the suggestions guys! Quote Link to comment Share on other sites More sharing options...
Stu Posted April 28, 2012 Share Posted April 28, 2012 Don't they have locating holes like all of the ones I have seen? Quote Link to comment Share on other sites More sharing options...
mattycoops43 Posted April 28, 2012 Author Share Posted April 28, 2012 No, not on there before, and the bars that came off are aftermarkwt anyway. Quote Link to comment Share on other sites More sharing options...
Stu Posted April 28, 2012 Share Posted April 28, 2012 Just out of interest take a look at the switch gear to see if it used to have the pins they might have been broken off for the old bars Quote Link to comment Share on other sites More sharing options...
mattycoops43 Posted April 29, 2012 Author Share Posted April 29, 2012 I will look and I expect they did have, but the new bars have no holes either so I'll try some thin rubber. Quote Link to comment Share on other sites More sharing options...
oslin06 Posted April 29, 2012 Share Posted April 29, 2012 I have had this on two other bikes i have had before I solved it by making up a stainless steel strip mounted from the switch forward clamp screw to the brake lever bolt, secures it all nicely.Keith Quote Link to comment Share on other sites More sharing options...
