Harri Posted January 4, 2015 Posted January 4, 2015 Hi all. I tried to drill as central as I could through the bolt but I've obviously not done that. The hole looks really close to the crankcase cover! Check out the pics. I've tried the extractor but to be honest I can't get enough torque to move the bolt in the slightest! I'm sure if I do manage to apply more torque the extractor itself is gonna snap.1. In the case of the crankcase thread being damaged - can that hole and the hole in the clutch cover be tapped to accept a larger bolt.2. What to do next? I could try a larger extractor but that will defo damage the crankcase as it will almost be the same size as the bolt hole. I could try a left hand drill bit but my drill will never be able to apply enough torque I don't think.any ideas guys? Quote
Mr Fro Posted January 4, 2015 Posted January 4, 2015 It's a bit tight in there but do you think you might be able to zap it with a bit of heat? A small blowtorch or similar would do.I'd give it a few sharp taps with a small metal headed hammer before that, just to see if that'd free it up. Quote
Harri Posted January 4, 2015 Author Posted January 4, 2015 Okay - this bolt ain't going nowhere Tried some heat and as much torque as I could physically apply with mole grips and no budge!I've checked out my drills and they both can be run in reverse so I just need to get hold of a left hand drill bit or two. raesewell sent a link so might order online.I reckon I'm as close/if not touching the crankcase already so a drill bit might just shave some off the casing. Can this hole be rethreaded for a larger bolt?Barcud Quote
cockercas Posted January 4, 2015 Posted January 4, 2015 If that easy out hasnt solved it then a reverse drill bit wont. Has the bolt started splitting from the easy out? Quote
cockercas Posted January 4, 2015 Posted January 4, 2015 Zooming it it looks like its been drilled and helicoiled before. Has it? Quote
Harri Posted January 4, 2015 Author Posted January 4, 2015 Hi, I'm not sure if the bolt is splitting, I thought it might be though can't be sure.The only other thing I was thinking was trying to whack the bolt to try and split it! Could be useless and dodgy though. And then it might just still sit there anyway Barcud Quote
Harri Posted January 4, 2015 Author Posted January 4, 2015 Helicoiled before? I'll take a look and a pic without the extractor in and see what you think.Barcud Quote
cockercas Posted January 4, 2015 Posted January 4, 2015 Nooo dont try and split it yet. Warm it up, not red hot just enough to get the metal to expand. Spray wd onto it. If you have time repeat a few times. Wipe excess wd off. If the bolt hasnt started to split you can apply more force. You want the correct handle for the easy out to. Or if your drill has hammer and will work in reverse on hammer you could try that to see if it will start to shock off. Quote
cockercas Posted January 4, 2015 Posted January 4, 2015 It dose look like its been helicoiled before. Quote
Tango Posted January 4, 2015 Posted January 4, 2015 Soak it in Plusgas overnight and try it again.... Quote
Harri Posted January 4, 2015 Author Posted January 4, 2015 Cheers guys, I've given up for the day after more heat, more gas and more torquing with the extractor. After quite a few hours it hasn't shifted one single bit!One of my links shows this to be a common problem with this engine so it may well have happened before and been rethreaded.Oh well. thanks for all the help. Quote
Stu Posted January 4, 2015 Posted January 4, 2015 I woulndt waste my time trying to get it out I would drill it larger tap it and put an insert in of the correct size and a new boltsomething like this http://www.bodyshop-tools-supplies.co.u ... oC70zw_wcB Quote
Harri Posted January 4, 2015 Author Posted January 4, 2015 Hi guys, I tried the smallest easy out to begin with. Then used the next size up.As for drilling out. The hole now has biased more to the left now and is not central. If I use a drill the bit will follow this hole and take out too much material on the left and it won't match up with the clutch cover hole. Do you agree?Barcud Quote
Tango Posted January 4, 2015 Posted January 4, 2015 Have you tried soaking it in Plusgas and leaving it and trying again with the easy out's.......penetrating oil may just do the trick..... Quote
cockercas Posted January 4, 2015 Posted January 4, 2015 Wd40 is the most mis used thing ever. Every one (I include myself) uses it as a penetrating oil. It's not that good at it either. Wd stands for water displacement and 40 was the number of attempts before they found something that worked. Quote
Tango Posted January 4, 2015 Posted January 4, 2015 Not really mate.......you really need proper penetrating oil like Plusgas or similar I think..... Quote
Harri Posted January 4, 2015 Author Posted January 4, 2015 Plusgas tomorrow then. While I'm out buying a new bottle for my blow torch Then another attempt with plusgas, heat, and the extractor. I've removed bolts and screws before but this muvver fu**er is something else. Barcud Quote
Stu Posted January 4, 2015 Posted January 4, 2015 another misconception about wd40 is that its not a penetrating oil here is just some of the uses of WD40 WHAT DOES WD-40® MULTI-USE PRODUCT DO?WD-40® MULTI-USE PRODUCT FULFILLS FIVE BASIC FUNCTIONS:LUBRICATES: The product's lubricating ingredients are widely dispersed and tenaciously held to all moving parts.PENETRATES: WD-40® Multi-Use Product loosens rust-to-metal bonds and frees stuck, frozen or rusted metal parts.PROTECTS: The product protects metal surfaces with corrosion-resistant ingredients to shield against moisture and other corrosive elements.REMOVES: WD-40® Multi-Use Product gets under dirt, grime and grease. Use it to remove gunk from tools, equipment and vehicles. WD-40® Multi-Use Product in liquid form (e.g., gallon) also dissolves adhesives, allowing easy removal of excess bonding material.DISPLACES MOISTURE: Because it displaces moisture, WD-40® Multi-Use Product quickly dries out electrical systems to eliminate moisture-induced short circuits. http://wd40.com/faqs Quote
cockercas Posted January 4, 2015 Posted January 4, 2015 Yer it dose penetrate, but it's shit in comparison.Wd40 was driven by marketing. And it's availability. Quote
Tango Posted January 4, 2015 Posted January 4, 2015 I've never had any success with WD40 as a penetrating oil.......but Plusgas has got me out of several fixes in the past..... Interestingly a search on google for Plusgas throws up comparisons with WD40......in which WD40 doesn't come out too rosy..... But it seems that Plusgas isn't so easy to get hold of now, which is a real shame......but it is still around......and smaller motor stores may still stock it..... Quote
Stu Posted January 4, 2015 Posted January 4, 2015 I wouldnt say its shit I would say its not as good as some out there WD40 needs longer to soak than others Quote
