Classickid21 Posted March 21, 2015 Share Posted March 21, 2015 (edited) sold the car back on a bike Edited July 14, 2015 by Classickid21 Quote Link to comment Share on other sites More sharing options...
Stu Posted March 21, 2015 Share Posted March 21, 2015 go find a forum for the starlet we are bikers who do stuff with bikes Quote Link to comment Share on other sites More sharing options...
Classickid21 Posted March 21, 2015 Author Share Posted March 21, 2015 Already posted on the ukso starlet forum, this is my cheap run about I have giving up with the idear and now gutted it too use as a van lol. Quote Link to comment Share on other sites More sharing options...
ScreaminEagle Posted March 21, 2015 Share Posted March 21, 2015 Is there anything near the sub with a live feed? Like a boot light or similar. If so, you could possibly attach to that, but would probably need to up the size of the fuse to that circuit. Quote Link to comment Share on other sites More sharing options...
cockercas Posted March 21, 2015 Share Posted March 21, 2015 Go throgh the grommet were the loom comes through the bulkhead. Quote Link to comment Share on other sites More sharing options...
Classickid21 Posted March 21, 2015 Author Share Posted March 21, 2015 Is there anything near the sub with a live feed? Like a boot light or similar. If so, you could possibly attach to that, but would probably need to up the size of the fuse to that circuit. already looked, and already wired a fuse in thanks for replying ive stripped it out now for time being may have another crack at it tomorrow Quote Link to comment Share on other sites More sharing options...
Classickid21 Posted March 21, 2015 Author Share Posted March 21, 2015 Go throgh the grommet were the loom comes through the bulkhead.someone has replied on the UKstarlet forum, that's its under the passager carpet so going to give it another crack tomorrow. thank you for replying Quote Link to comment Share on other sites More sharing options...
Grumpy Old Git Posted March 22, 2015 Share Posted March 22, 2015 What type of motorcycle is a 'Starlet'? Is it Chinese?You putting the Sub-Woofer into your top box?Is the sub-woofer just another dumb dog?Is the world still spinning?Of out on t'bike - Bye! Quote Link to comment Share on other sites More sharing options...
fq-craigus Posted March 22, 2015 Share Posted March 22, 2015 If you have no joy with the carpet one just look from the bonnet side and look where there is a congrigation of wires going through, poke the live through and then look for the big red cable on the inside. Failing that i know plenty of people that chased them through the nearside wing into the door shut and then under the trim and do it that way. Good luck i gave up with systems years ago cant hear them over the exhaust on the car Quote Link to comment Share on other sites More sharing options...
Joeman Posted March 22, 2015 Share Posted March 22, 2015 Just make sure you put a fuse close to the battery. If the cable shorts on the bulkhead and you dont have a fuse, you will have a fire!! Quote Link to comment Share on other sites More sharing options...
eastanglianbiker Posted March 22, 2015 Share Posted March 22, 2015 Just make sure you put a fuse close to the battery. If the cable shorts on the bulkhead and you dont have a fuse, you will have a fire!!will be one less cage out there on the roads Quote Link to comment Share on other sites More sharing options...
Grumpy Old Git Posted March 23, 2015 Share Posted March 23, 2015 Just make sure you put a fuse close to the battery. If the cable shorts on the bulkhead and you dont have a fuse, you will have a fire!!will be one less cage out there on the roads And a nice camp fire to warm yourself on when the weather is cold (like this morning). Quote Link to comment Share on other sites More sharing options...
JamBerryKing Posted March 24, 2015 Share Posted March 24, 2015 when i used to be into installing subwoofers and amps in to my cars, if the grommet was a massive pain the ass, i just drilled through the firewall and put some sealant around it after i fed the cable through Quote Link to comment Share on other sites More sharing options...
Guest Posted March 27, 2015 Share Posted March 27, 2015 Go throgh the grommet were the loom comes through the bulkhead.someone has replied on the UKstarlet forum, that's its under the passager carpet so going to give it another crack tomorrow. thank you for replyingDone this to a few of my cars in the past... yes, it's usually at sort of behind the glove box. Running the wiring from the back to the front is usually a bit fiddly but always can be done. Quote Link to comment Share on other sites More sharing options...
DreamytimeEscorts Posted March 28, 2015 Share Posted March 28, 2015 hiI have wired in a subwoofer with amp etc. I have one problem I can not get the red positive lead to the battery. with out drilling a hole I am having no luck any idears ? Toyota Starlet ep91 Try going through somewhere that goes through the bulkhead. Pedals, behind-dash wiring (a lot a hassle) or look for somewhere under the carpet where wiring may go through that's already there for lighting/switches etc. Drilling a hole isn't a problem as such but make sure you protect the red wire with a grommet or such because you'll have a word of problems if it chafes and eventually earths itself on the hole you drilled Quote Link to comment Share on other sites More sharing options...
Classickid21 Posted April 1, 2015 Author Share Posted April 1, 2015 Found away through the bulk head with a gromet... I just been offered a honda NSF with nsr plastics running but fell over twice in the horrible wind. Tempted to do the trade and do away with the car Quote Link to comment Share on other sites More sharing options...
Grumpy Old Git Posted April 2, 2015 Share Posted April 2, 2015 Will your sound system fit the NSF? Quote Link to comment Share on other sites More sharing options...
