Phooey Posted April 8, 2015 Share Posted April 8, 2015 Swopping out the rear wheel bearings today and noticed that the cushdrive rubbers are quite loose in the casing. How loose is too loose? Is there a 'test' I could do? Quote Link to comment Share on other sites More sharing options...
Tango Posted April 8, 2015 Share Posted April 8, 2015 The rear sprocket shouldn't move relative to the wheel.......if it can rotate slightly within the rear wheel you probably need new cush drive rubbers..... Quote Link to comment Share on other sites More sharing options...
Phooey Posted April 8, 2015 Author Share Posted April 8, 2015 Thanks Tango ... New cushdrive required then Quote Link to comment Share on other sites More sharing options...
megawatt Posted April 8, 2015 Share Posted April 8, 2015 I shimmed my Fireblade ones with some 1mm thick aluminium. Never had a problem since and done 5 trackdays. Quote Link to comment Share on other sites More sharing options...
Phooey Posted April 8, 2015 Author Share Posted April 8, 2015 I could pack it out to take up the slack. Even if only temporary. Quote Link to comment Share on other sites More sharing options...
megawatt Posted April 8, 2015 Share Posted April 8, 2015 Yep. Quote Link to comment Share on other sites More sharing options...
GazW Posted April 8, 2015 Share Posted April 8, 2015 Kawasaki ones are notoriously slack from standard.If you look on the sprocket carrier, there will be 5 lugs that knit into the rubbers when it all fits together. Slip an old bit of innertube over them.Edit;http://images.tapatalk-cdn.com/15/04/08/460fdad3a69d515c350439417075fd96.jpgThem bits, generic photo, Quote Link to comment Share on other sites More sharing options...
Stu Posted April 8, 2015 Share Posted April 8, 2015 yup the old inner tube trick works too Quote Link to comment Share on other sites More sharing options...
megawatt Posted April 9, 2015 Share Posted April 9, 2015 Or alloy shims over the webs in the wheel. Quote Link to comment Share on other sites More sharing options...
Phooey Posted April 9, 2015 Author Share Posted April 9, 2015 Packed it out with bits of plastic for time being. Kawasaki has to place an order, two weeks wait.I've seen a couple of s/hand one on fleabay for £12 but I hate taking the chance that they are just as bad, if not worse than my one!Still, seems to have sorted it for a a couple of weeks. Bike all back together again Can't believe what I've managed to achieve in the past few weeks ... and to think I can barely change a light bulb without a detailed instruction manual! lol Quote Link to comment Share on other sites More sharing options...
megawatt Posted April 9, 2015 Share Posted April 9, 2015 Top bodging Quote Link to comment Share on other sites More sharing options...
Kawamad Posted April 9, 2015 Share Posted April 9, 2015 Not bodging 'top quality alternative maintenance technique' Quote Link to comment Share on other sites More sharing options...
whitedevil Posted April 9, 2015 Share Posted April 9, 2015 my gpz was terrible for this, i just packed it with an old innertube and it was good for a few years lol Quote Link to comment Share on other sites More sharing options...
