Will0104 Posted February 19, 2016 Share Posted February 19, 2016 Put a new exhaust on my ybr125 and i have noticed that the chain now ever so slightly is touching the center stand when up. I dont really know any way to make the exhaust lower therefore the metal that holds the stand away from chain down. Quote Link to comment Share on other sites More sharing options...
eastanglianbiker Posted February 19, 2016 Share Posted February 19, 2016 does the new exhaust sit higher than the original one if so where the bump stop would normally be for the stand you might need to put a bracket on to lower it slightly.....................or is your chain very slack and needing adjusting?? Quote Link to comment Share on other sites More sharing options...
Will0104 Posted February 19, 2016 Author Share Posted February 19, 2016 Chain was only tightened about a week or two ago so isnt the problem. The problem is there isnt a way to make the exhaust sit lower that i can see as it is bolted to the frame Quote Link to comment Share on other sites More sharing options...
Stu Posted February 19, 2016 Share Posted February 19, 2016 Chain was only tightened about a week or two ago so isnt the problem. The problem is there isnt a way to make the exhaust sit lower that i can see as it is bolted to the frame you may have done a million miles in that week or two!!! I have known chains to need adjusting every day when they are on their last legs can you post pics of the problem Quote Link to comment Share on other sites More sharing options...
iangaryprice Posted February 20, 2016 Share Posted February 20, 2016 1. Check chain tension.2. Check exhaust is correctly positioned. 3. Is the rubber bump stop for the centre stand fitted.4. Put a spacer or bigger bump stop to move the stand lower to get it away form the chain.Quality of aftermarket parts vary. Some just bolt on and work well, others need a bit of fettling to get hem right. Quote Link to comment Share on other sites More sharing options...
Will0104 Posted February 20, 2016 Author Share Posted February 20, 2016 I don't get what you mean by checking the exhaust is positioned properly, surely if the screws are lined up with the hole/exhaust firmly attached it must in the right position? Quote Link to comment Share on other sites More sharing options...
eastanglianbiker Posted February 20, 2016 Share Posted February 20, 2016 it might be sitting higher than the original did hence the stand will sit higher under the bike did the original exhaust have a rubber stopper on the underside of it for the stand to rest on and if so has the new exhaust also got one if not you might need to make a bracket up to go from the bolt that it mounts on to under the bike for the stand to rest on Quote Link to comment Share on other sites More sharing options...
Tango Posted February 20, 2016 Share Posted February 20, 2016 agree with EAB.......check the position of the stand stop.....If the new exhaust has one..... Quote Link to comment Share on other sites More sharing options...
Lumor_uk Posted March 15, 2016 Share Posted March 15, 2016 I have known chains to need adjusting every day when they are on their last legs Has happened twice to me Quote Link to comment Share on other sites More sharing options...
