Speedmaster865 Posted July 9, 2018 Posted July 9, 2018 I've just bought Fazer fzs600 ,2001.I only have one ignition key.Does the MK1 FZS, have ordinary keys?I know later models have a chip in them.Does the MK1 key have a chip? Quote
mikestrivens Posted July 9, 2018 Posted July 9, 2018 hello & welcome.You should be able to get spare keys from dealer, as long as you have the appropriate paperwork. Quote
Speedmaster865 Posted July 10, 2018 Author Posted July 10, 2018 Thanks Mike.Only paperwork I have is the V5.I was told that the key has a chip.But I now think that its later models that have that. Quote
Mr Fro Posted July 10, 2018 Posted July 10, 2018 Thanks Mike.Only paperwork I have is the V5.I was told that the key has a chip.But I now think that its later models that have that. Order a blank from eBay and get it cut at your local key place.If it doesn't work on it's own but does when you hold the original near the headstock then you have a chip. Quote
Speedmaster865 Posted July 10, 2018 Author Posted July 10, 2018 Thanks, it sounds like a good plan to me Quote
TimR Posted July 10, 2018 Posted July 10, 2018 go jnto a local timpson with v5 they may be able to clone the key Quote
leener Posted July 18, 2018 Posted July 18, 2018 You can probably get a replacement with transponder easily enough.I have no idea if this is the same:https://www.ebay.co.uk/itm/Yamaha-YZF-R1-R6-FZ1-FZ4-FZ6-FZ8-XJ6-XJR-Schlussel-Rohling-Transponder-ID69/152602096860?hash=item2387cb34dc%3Ag%3ANPAAAOSw9~5ZUldx&_sacat=0&_nkw=fz6+key+transponder&_from=R40&rt=ncAnd then a process to program the transponder to the ECU:1.Insert the red key into the ignition and turn it to "ON". The immobilizer indicator light should come on for 1 second and then go off. 2.With the red key still in the ignition, start the engine. 3.Shut off the engine and remove the red key. The immobilizer indicator light should start to blink after 30 seconds. 4.Insert the red key into the ignition and turn it to "ON", then "OFF" and then remove the key within 5 seconds. 5.Insert the black key into the ignition and turn it to "ON" within 5 seconds. 6.While the immobilizer indicator light is flashing, turn the black key to "OFF" and then remove the key. 7.Wait for the immobilizer indicator light to stop flashing. It should stop 5 seconds after you remove the black key. 8.If everything went OK, then you can use the black key to start the engine.I had to do something similar with a few cars over the years but never had a bike new enough with a chip in it. Quote
Speedmaster865 Posted July 18, 2018 Author Posted July 18, 2018 Thanks for info, but I only have one black key. Quote
Speedmaster865 Posted July 18, 2018 Author Posted July 18, 2018 I have checked and definitely has a chipped key.I've had a spare key cut, and it operates the ignition normally. But the immobiliser prevents the engine from turning over to start.If I hold the old key against the key/ lock housing, and the new key inserted, the engine starts ok. Quote
