Manual for a clr125 cityfly
Ray Jeffrey
Its got the same engine as an XLR 125 and there is a Haynes manual for that bike . At the end of the day this is pretty much a generic Honda four stroke SOHC motorcycle . If you know a bit about bikes then there isn't going to be anything about it that you haven't seen before. A wheel bearing is still a wheel bearing for example so you might do better to get Haynes Motorcycle Basics or check out a few YouTube vids if you are unsure how to go about anything specific. If you get stuck , start a thread in Old Bikes Projects and Restorations in this forum WITH PICTURES and we will help you out .
  • 4 months later...
Hi ray
Have you found a manaul i also have a project bike clr 125 t plate . Need to remove carburetta runs but plug is sooty been standing a while need to clean carb and maybe replace float parts
Any other things youve found like cheap spares appreciated
  • 2 weeks later...
  • Sign up now
