Simon Davey Posted August 16, 2024 Posted August 16, 2024 So (yesterday) I replaced the standard front brake hoses. The original was a single line to a T above the mudguard, then one each side to the calipers. I've fitted a HEL two line system, which is a line to each caliper from a double banjo on the master cylinder. Easier to bleed through, and a great braking response. 2 Quote
AstronautNinja Posted August 16, 2024 Posted August 16, 2024 (edited) Refitted the baffle and sanded away the "not for road use" etching from the end can followed by a cheeky buff back to finish Edited August 16, 2024 by AstronautNinja 1 2 Quote
Simon Davey Posted August 16, 2024 Posted August 16, 2024 19 minutes ago, AstronautNinja said: Refitted the baffle and sanded away the "not for road use" etching from the end can followed by a cheeky buff back to finish You've not even taken it out yet..... Although, I bet you've had a couple of blasts down the road, at least. 1 Quote
AstronautNinja Posted August 16, 2024 Posted August 16, 2024 14 minutes ago, Simon Davey said: You've not even taken it out yet..... Although, I bet you've had a couple of blasts down the road, at least. Nope. Mod 2 is booked for 10th September, zero chance I'm risking points for a quick ride. I get enough opportunities to ring the cars neck to avoid temptation 1 Quote
Nick the wanderer Posted August 17, 2024 Posted August 17, 2024 12 hours ago, AstronautNinja said: Refitted the baffle and sanded away the "not for road use" etching from the end can followed by a cheeky buff back to finish When do we get to see this bike of yours? Quote
AstronautNinja Posted August 17, 2024 Posted August 17, 2024 (edited) 6 minutes ago, Nick the wanderer said: When do we get to see this bike of yours? I probably posted in the project thread but here's a quick snap from last week. Still to refit the lower fairing. I will almost certianly end up putting a more civil end can on after my first few weeks of childish noise making becomes less novel. Edited August 17, 2024 by AstronautNinja 4 Quote
Nick the wanderer Posted August 17, 2024 Posted August 17, 2024 There are plenty of db killers you can try to take the edge off, they slot into the exhaust between the pipe and the can. Plus you can baffle the can more. If it proves too loud. 1 Quote
AstronautNinja Posted August 17, 2024 Posted August 17, 2024 5 minutes ago, Nick the wanderer said: There are plenty of db killers you can try to take the edge off, they slot into the exhaust between the pipe and the can. Plus you can baffle the can more. If it proves too loud. Cheers. I very much misjudged how violent this pipe was going to be Quote
Nick the wanderer Posted August 17, 2024 Posted August 17, 2024 Measure your pipe internal diameter for this type of thing between pipe and can, just slots in. Measure the internal diameter of the end of the can for something like this. Bolts in. 1 1 Quote
Bianco2564 Posted August 18, 2024 Posted August 18, 2024 Cleaned up one pair of the power valves, had them soaking in white spirit all week to soften the carbon. Pic is one set in pieces, the roll pin in the middle blade is the offending part that fails, this then allows the blade to slide too far and hit the piston, not a great design. Mine are a later version with double roll pins. There are billet ones available from Cougar but these are many £££s. 1 Quote
bud Posted August 18, 2024 Posted August 18, 2024 Changed the head stock bearings. It's one job i hate doing. Loads of waterproof grease was used. So hopefully won't need to do it again. 4 Quote
RideWithStyles Posted August 19, 2024 Posted August 19, 2024 On 17/08/2024 at 11:14, Nick the wanderer said: Measure your pipe internal diameter for this type of thing between pipe and can, just slots in. Measure the internal diameter of the end of the can for something like this. Bolts in. Bolts secure versions are easier to install/take out but are more likely to disappear when you don’t expect it. the internal cur ring types are more secure but not quite as convenient. most designs don’t really allow much room so are a git to get on and even worse to get off, especially if flies off into your face or far away somewhere. Quote
Simon Davey Posted August 21, 2024 Posted August 21, 2024 (edited) Just fitted a pair of Grip Puppies. Not the best looking accessory for a sport bike, but then, at 20 years old, it's not the best looking sport bike Having removed the Oxford heated grips, I found my fingers were wrapping right around the new grips I'd since fitted, and I was getting a bit of mid-range vibration. Now though, Just placing my hand around the fitted Grip Puppies I can feel instant comfort, and I should also get better circulation in my fingers. Edited August 21, 2024 by Simon Davey 3 Quote
Stu Posted August 23, 2024 Author Posted August 23, 2024 Fitted another rear tyre yesterday I'm going through one in less than a year at the moment Although the one I have just taken off still had a bit of life left in it but I'm off to Wales again in a couple of weeks so best to be safe than sorry 3 Quote
Simon Davey Posted August 23, 2024 Posted August 23, 2024 (edited) @Stu What tyres do you put on a big machine like that? Edited August 23, 2024 by Simon Davey Quote
Stu Posted August 23, 2024 Author Posted August 23, 2024 1 hour ago, Simon Davey said: @Stu What tyres do you put on a big machine like that? Michelin road 6 gt Thinking of trying something different next though as I'm looking at over 320 for the set and there is other tyres that are just as good these days! 1 Quote
Simon Davey Posted August 23, 2024 Posted August 23, 2024 (edited) My bike is heavy, not knowing what I needed, chap replaced the Road 4's with Bridgestone Battlax T31. Only done 400 miles or so on them, they feel good, but not amazing. Time will tell. Edited August 23, 2024 by Simon Davey 2 Quote
Stu Posted August 23, 2024 Author Posted August 23, 2024 I was looking to go bridgestones I had a set on when I first got the bike but I can't remember what model they was! They felt good and was good in the wet too 1 Quote
Bianco2564 Posted August 23, 2024 Posted August 23, 2024 Picked my RGV frame from the welders. Was done at ETTO Motorcycles, he specialises in making aluminium fuel tanks. https://www.ettomotorcycles.co.uk 3 Quote
AstronautNinja Posted August 23, 2024 Posted August 23, 2024 28 minutes ago, Bianco2564 said: Picked my RGV frame from the welders. Was done at ETTO Motorcycles, he specialises in making aluminium fuel tanks. https://www.ettomotorcycles.co.uk Looks guuuuud shiny is guuuuud 1 Quote
V650 Posted August 23, 2024 Posted August 23, 2024 9 hours ago, Simon Davey said: My bike is heavy, not knowing what I needed, chap replaced the Road 4's with Bridgestone Battlax T31. Only done 400 miles or so on them, they feel good, but not amazing. Time will tell. I have the T31 on my CB500X have not had any issues with them hopefully it stay's that way 1 Quote
veracocha Posted August 24, 2024 Posted August 24, 2024 I had a tyre with 43 miles on it replaced due to a puncture (£229). Then I fitted a lowering link to drop it 1 inch from standard. Now both feet are flat on the ground. 1 1 Quote
rob m Posted August 24, 2024 Posted August 24, 2024 Cleaned the radiator today, sorry didn't take pictures as I was doing it in between rain showers. I noticed it getting hotter last week while sat in traffic. It's an annoyance with K12/13 models. Oh, and the K1600 too. They're positioned right where the road shite flicks up and gums them up. I have a Powerbronze fender extender on the front mudguard, not sure it makes much difference tbh. Cleaning them is an annual thing but I've done mine once already this year. It can be done in situ, only have to remove the fan and hose it from the back. Loads of muck came out. Anyway, ran it afterwards and the fan kicked in as expected and everything is good again. Back to 3 bars on the temp gauge. I think it'll need replacing next year but for a bike that is 13 years old, that isn't too bad I think. 5 Quote
peepae Posted August 25, 2024 Posted August 25, 2024 Got an adaptor plate for a Givi Topbox - I just can't get myself to put it on, it's too ugly.. but then I guess a top box is also ugly. Quote
