hardleydavidson Posted June 4, 2020 Posted June 4, 2020 Hi,Not having ridden the bike for a few years and being a complete novice I forgot to turn off the fuel tap. The bike had been sat in the garage for a few days (missing it's air filter but with the choke on) and when I returned to it the tank was empty.Now I know there are no fuel leaks on it, none at all, did a complete check before I put fuel in it. Is it possible for fuel to evaporate through the carb if the tap is left on? Quote
dynax Posted June 4, 2020 Posted June 4, 2020 There is a good chance it has leaked out somewhere, petrol can evaporate quite quickly in the open air Quote
Bender Posted June 4, 2020 Posted June 4, 2020 Check your oil, it may have been diluted by petrol. Quote
JRH Posted June 4, 2020 Posted June 4, 2020 No. If the float in the carb has stuck open petrol will overflow from it. It could do as bender suggested by finding its way into the sump. Or it may have gone into the air filter area and evaporated. Quote
Mississippi Bullfrog Posted June 4, 2020 Posted June 4, 2020 If it had evaporated in a garage you'd probably smell it. So I'd double check it hasn't seeped into your sump. If so, apologies for stating the obvious, but drain the oil and replace it. Quote
James in Brum Posted June 4, 2020 Posted June 4, 2020 My garage smells of petrol. Hoping it is just evaporation. Quote
WD-40 Posted June 5, 2020 Posted June 5, 2020 A float valve not seating properly or float height problem would explain your previous question about being too rich causing black spark plugshttps://www.themotorbikeforum.co.uk/viewtopic.php?f=5&t=72700 Quote
