5 hours ago, Mickly said:
The Trophy is going into R&RP for jetting on Friday, but only dropping it off as going in hols, the dyno work may not be done for a week or so.
If all is successful I want them to MoT it as well, so I’ve fitted the original number plate - should upset a few flag shaggers - hopefully 😁04F766F9-061F-481E-99E6-D568309C8869.thumb.jpeg.4ec81d187a7516512205e6e17010c8be.jpeg
Although I did not vote for Brexit , I decided to stick a Union Jack over mine .
  • 1 month later...
So R&RP have done the running in process on their Dyno …
No water or oil leaks 👍
No slipping clutch 👍
No smoke out of the exhaust 👍
No untoward noises 👍
Clip on handlebar wasn’t tight enough & moved when the guy was pushing it onto the dyno causing him to believe it was falling over & put his under crackers in jeopardy 👎
Initial view is that the fuelling needs much fettling £ £ 😬
Proper Dyno calibration will be over the next week 🤞
  • Like 3
No untoward noises . Definitely not a Harley . 😎
  • Haha 2
