Hi all, I have a 2007 Suzuki GSXR-600. I have an issue with the clutch i believe, when my bike is on or off in neutral or not the bike will not role,when i put it in first gear it will not go and just eventually turn off. a few days ago it was fine it rolled, This issue comes and goes. Any ideas on what the problem is and how o fix it?
Posted (edited)
I've no idea but just as a suggestion, does it roll when you pull the clutch lever in?
Edited by goat
Posted (edited)
Sounds like a clutch failure . I wouldn't run it again until I'd had the whole clutch pack out and inspected for thickness and warpage . I've actually got the feeling that it may be a bit more obvious than that though . I reckon you've got some detached friction plate material floating around inside the basket . I have to agree that your description of the symptoms is rather unclear .
Edited by fastbob
