Justboughtabike Posted December 18, 2021 Posted December 18, 2021 Hi, Looking at buying a rack to attach a top box to my Honda CG125 and wondered if there was specific size/model I needed buy? Or are racks universal and fit for all motorbikes? Any help would be great Quote
fastbob Posted December 18, 2021 Posted December 18, 2021 What year and model CG have you got please ? Quote
Justboughtabike Posted December 20, 2021 Author Posted December 20, 2021 Actually not certain but done a post on here with pictures if that helps - Quote
fastbob Posted December 20, 2021 Posted December 20, 2021 4 minutes ago, Justboughtabike said: Actually not certain but done a post on here with pictures if that helps - I remember now . You've got the Japanese retro version with the one up , four down gearbox . Quote
Justboughtabike Posted December 20, 2021 Author Posted December 20, 2021 That's me Fastbob! Any ideas what rack i get? Quote
billy sugger Posted December 21, 2021 Posted December 21, 2021 There is two on fleabay that are for your bike Quote
fastbob Posted December 21, 2021 Posted December 21, 2021 15 hours ago, Justboughtabike said: That's me Fastbob! Any ideas what rack i get? As as I can determine it should look like this in terms of the fixing points . The front two go under the nuts that hold the shocks on . The other two I'm not sure about . Because there at least a dozen Chinese copies of your bike , one would assume that there would be numerous copies of a rack . I've found a few but they are hidious looking contraptions aimed at the Third World marketplace . Anyway now that you have an idea what to look for , I wish you luck in your search . May I suggest that you join the CG FB page . Quote
Mississippi Bullfrog Posted December 21, 2021 Posted December 21, 2021 1 hour ago, fastbob said: As as I can determine it should look like this in terms of the fixing points . The front two go under the nuts that hold the shocks on . The other two I'm not sure about . Because there at least a dozen Chinese copies of your bike , one would assume that there would be numerous copies of a rack . I've found a few but they are hidious looking contraptions aimed at the Third World marketplace . Anyway now that you have an idea what to look for , I wish you luck in your search . May I suggest that you join the CG FB page . On later CG models there was a rear fairing with two bolts that lined up with the other two lugs on that rack. If you remove your seat and take a photo it would be helpful to see what fittings are there. Quote
fastbob Posted December 21, 2021 Posted December 21, 2021 50 minutes ago, Mississippi Bullfrog said: On later CG models there was a rear fairing with two bolts that lined up with the other two lugs on that rack. If you remove your seat and take a photo it would be helpful to see what fittings are there. But this isn't a later CG model . Quote
billy sugger Posted December 21, 2021 Posted December 21, 2021 The other 2 fittings go where the indicators fit, then they bolt on to the rack Quote
Mississippi Bullfrog Posted December 21, 2021 Posted December 21, 2021 22 minutes ago, fastbob said: But this isn't a later CG model . I know - but you said you weren't sure where other two lugs connected to on the rack shown. @billy sugger has it right - on that model it looks like they connect where the indicators go. On mine they connected to the bolts in the rear fairing. Which is why I suggested taking a photo with the seat off because it will show what will line up. That will make it easier to figure out which rack will fit. 1 Quote
billy sugger Posted December 21, 2021 Posted December 21, 2021 The 2 I said are on fleabay will fit 1 Quote
fastbob Posted December 21, 2021 Posted December 21, 2021 On 20/12/2021 at 17:00, Justboughtabike said: That's me Fastbob! Any ideas what rack i get? Ok I've found someone who says they have one on the CG Facebook page . If you join , you can link up . https://m.facebook.com/groups/cg125uksales/permalink/1020449761875323/ 2 Quote
Justboughtabike Posted December 22, 2021 Author Posted December 22, 2021 On 21/12/2021 at 08:16, fastbob said: As as I can determine it should look like this in terms of the fixing points . The front two go under the nuts that hold the shocks on . The other two I'm not sure about . Because there at least a dozen Chinese copies of your bike , one would assume that there would be numerous copies of a rack . I've found a few but they are hidious looking contraptions aimed at the Third World marketplace . Anyway now that you have an idea what to look for , I wish you luck in your search . May I suggest that you join the CG FB page . Ok nice one for that, i'll keep an eye for this style of rack. Thanks for the advice Quote
Justboughtabike Posted December 22, 2021 Author Posted December 22, 2021 On 21/12/2021 at 10:01, Mississippi Bullfrog said: On later CG models there was a rear fairing with two bolts that lined up with the other two lugs on that rack. If you remove your seat and take a photo it would be helpful to see what fittings are there. Ok, i'm actually away atm but I'll be back Christmas Eve to take a pic and upload. Cheers Quote
Justboughtabike Posted December 22, 2021 Author Posted December 22, 2021 On 21/12/2021 at 11:20, billy sugger said: The 2 I said are on fleabay will fit You got a link to the fleabay racks? Quote
Justboughtabike Posted December 22, 2021 Author Posted December 22, 2021 On 21/12/2021 at 19:00, fastbob said: Ok I've found someone who says they have one on the CG Facebook page . If you join , you can link up . https://m.facebook.com/groups/cg125uksales/permalink/1020449761875323/ Good stuff, will sign up now Quote
billy sugger Posted December 23, 2021 Posted December 23, 2021 1 hour ago, Justboughtabike said: You got a link to the fleabay racks? https://picclick.co.uk/Honda-CG125-Rear-rack-Rickman-Top-Box-183343395938.html Quote
Lloyd777 Posted May 31, 2022 Posted May 31, 2022 Looking for the same rack, been searching and contacting companies, any pointers Honda cg125 1977 Quote
