Danw1993 Posted January 10, 2022 Share Posted January 10, 2022 Hi good afternoon I have got a Yamaha yzf r125 i Turned the key wait for all light to go out and pressed the switch and bike not starting each time I pressed it it makes a clicking sound and it’s coming from the starting relay could this be the case Quote Link to comment Share on other sites More sharing options...
Tiggie Posted January 10, 2022 Share Posted January 10, 2022 Welcome to the forum First thing I'd do is make sure the battery has a full charge. Clicking is usually a dead battery. Quote Link to comment Share on other sites More sharing options...
iangaryprice Posted January 10, 2022 Share Posted January 10, 2022 11 minutes ago, Tiggie said: Welcome to the forum First thing I'd do is make sure the battery has a full charge. Clicking is usually a dead battery. Yes, this is the first thing to do. Check it, charge ti if required, usea voltmeter on the battery while trying to start. Record the voltages. If it has a kickstart, try that. Or try a push start. If your battery is OK, then ask again. Quote Link to comment Share on other sites More sharing options...
Danw1993 Posted January 10, 2022 Author Share Posted January 10, 2022 (edited) I did charge the battery and still nothing that’s the first thing I did Edited January 10, 2022 by Danw1993 Quote Link to comment Share on other sites More sharing options...
Copycat73 Posted January 10, 2022 Share Posted January 10, 2022 and what was the voltage reading after you charged it ? 1 Quote Link to comment Share on other sites More sharing options...
