Rickstar gaming Posted May 9, 2023 Posted May 9, 2023 I have not long bought a factory Honda cb125r and for the past two days any time I’m in third gear if I open the throttle my rpm goes max but the speed doesn’t increase is there anyone who might have an idea as too what’s up with the bike Quote
Stu Posted May 9, 2023 Posted May 9, 2023 hi and welcome It sounds like your clutch is slipping 3 Quote
onesea Posted May 10, 2023 Posted May 10, 2023 4 hours ago, Stu said: hi and welcome It sounds like your clutch is slipping Check the tension on the clutch cable when clutch is out it should just be slack Quote
husoi Posted May 10, 2023 Posted May 10, 2023 (edited) I had a similar problem with me shadow when I bought it and found out the engine oil was the wrong spec/quality. Try some seafoam and see if it works better. Cheaper than a new clutch Unless your clutch works on the dry.. Edited May 10, 2023 by husoi Quote
