Angela Collen Posted July 15, 2023 Share Posted July 15, 2023 Hi all, getting along well fixing my 40 year old honda cb400nc superdream 1982, but would like your advise on replacing old rubber brake tubing to new braided version, where can I source to fit on my bike, is there a universal type or does it vary bike to bike, I cannot find on the usual buying sites eg david silver, do I need to know length and type of fixing? Your help would be appreciated as I'm learning on the job after returning to motorbikes after 40 years out, the front brake is disc not drum, thank you for your time Quote Link to comment Share on other sites More sharing options...
Mickly Posted July 15, 2023 Share Posted July 15, 2023 This what your looking for? https://www.helperformance.com/hel-oem-replacement-braided-brake-lines-for-honda-cb400-n-superdream-1978-1981 Quote Link to comment Share on other sites More sharing options...
Angela Collen Posted July 15, 2023 Author Share Posted July 15, 2023 Thank you for taking the time to reply, seems exactly what I need,much appreciated 2 Quote Link to comment Share on other sites More sharing options...
Angela Collen Posted August 1, 2023 Author Share Posted August 1, 2023 Update on new braided brakes lines, I contacted hel to confirm these fitted my bike as year was only up to 1981, my bike is 1983, they replied back 'they should fit,we're probably got our years wrong' I was not filled with confidence on making £100 purchase, I also contacted venhill (www.venhill.co.uk) and Tyler Baldwin from [email protected] replied and he actually measured all parts of lines, even small bits and sent me a diagram, this enabled me to know their lines would fit, so I have ordered from them with confidence I wasn't chucking £100 down the drain, if your not sure, contact them and they go above and beyond to help you get the right ones 4 1 Quote Link to comment Share on other sites More sharing options...
Stu Posted August 1, 2023 Share Posted August 1, 2023 29 minutes ago, Angela Collen said: Update on new braided brakes lines, I contacted hel to confirm these fitted my bike as year was only up to 1981, my bike is 1983, they replied back 'they should fit,we're probably got our years wrong' I was not filled with confidence on making £100 purchase, I also contacted venhill (www.venhill.co.uk) and Tyler Baldwin from [email protected] replied and he actually measured all parts of lines, even small bits and sent me a diagram, this enabled me to know their lines would fit, so I have ordered from them with confidence I wasn't chucking £100 down the drain, if your not sure, contact them and they go above and beyond to help you get the right ones Venhill are better quality too 1 Quote Link to comment Share on other sites More sharing options...
