NO brake lights
recoveryone
Go to solution Solved by Tiggie,
Rear light works. Brightly ?
Pull front lever light goes out.
Depress foot brake nothing happens
Put new switch on front lever
Still no brake lights
Yamaha 650 1982 chopper
Any ideas please
  • Solution
I'd have a look at the wire harness by the light and see if something is corroded, disconnected or otherwise damaged.
If all looks ok I would trace the wires back along the loom checking for insulation worn away due to rubbing or corrosion etc
  • Thanks 1
Any ideas please
Is that a haiku?
Sounds like it could be a bad earth, but maybe two separate issues.  Maybe just focus on the front brake first.
  • Haha 3
Being a chopper the harness might be home brewed, look up a standard harness for ( I’m guessing ) a XS650 heritage.
is the bike new to you or is this a problem that has just happened?
  • 2 weeks later...
The wires in the light holder were the problem. Thanks you were right.👍👍
  • Like 2
