geofferz Posted December 17, 2023 Author Posted December 17, 2023 3 hours ago, Essem said: Get access to GitHub copilot, it will write the code for you pretty much Doesn't sound like a good way to learn! 1 Quote
Bender Posted December 17, 2023 Posted December 17, 2023 41 minutes ago, geofferz said: Doesn't sound like a good way to learn! Good way to check, if it's accurate Quote
geofferz Posted December 17, 2023 Author Posted December 17, 2023 17 minutes ago, Bender said: Good way to check, if it's accurate True Quote
geofferz Posted December 18, 2023 Author Posted December 18, 2023 16 hours ago, Grumpy Old Git said: I had a cold a while ago. They have repositories for that on git hub... 1 Quote
Grumpy Old Git Posted December 18, 2023 Posted December 18, 2023 I can decode Morse (and some Semaphore) if that helps? 1 Quote
Essem Posted December 18, 2023 Posted December 18, 2023 On 17/12/2023 at 18:45, geofferz said: Doesn't sound like a good way to learn! Just tell it what you want, then ask for explanation anything not understood Quote
geofferz Posted December 19, 2023 Author Posted December 19, 2023 2 hours ago, Essem said: Just tell it what you want, then ask for explanation anything not understood Annoying it often categorically makes up things; yes admits it when questioned, but still what do you believe? Quote
bonio Posted December 19, 2023 Posted December 19, 2023 9 hours ago, geofferz said: Hard to believe, but it always categorically makes everything up; yes it often gets it right by chance, but still what do you believe? Spot on. Quote
geofferz Posted December 19, 2023 Author Posted December 19, 2023 1 hour ago, bonio said: Spot on you sexy man. That confused the hell out of me initially! 1 Quote
bonio Posted December 19, 2023 Posted December 19, 2023 17 hours ago, geofferz said: ... admits it when questioned Just as a test, the next time it tells you something, and when you look at it carefully you find it's correct, then challenge it. See how quickly it backs down and apologies. Quote
Essem Posted December 22, 2023 Posted December 22, 2023 On 19/12/2023 at 00:07, geofferz said: Annoying it often categorically makes up things; yes admits it when questioned, but still what do you believe? When I used it, I wanted it to do just that. My background is coding but only limited web stuff. When I needed to make some web stuff with user interaction, rather than spend time learning HTML, CSS, JavaScript etc, I paid for GitHub copilot and instructed it to do the donkey work. 1 Quote
