Headlights
Scouse
37 minutes ago, RideWithStyles said:
lets put it this way your gonna have to bite the "for the life of the bike BS" its not a bulb so its not cheap.
If its LED you have to but the head light unit sometimes separate and sometimes both....
It’s  a 2020 model so it’s led don’t know if I can replace the bulb or the whole unit which is just over £200
A few years ago I had a Honda VFR 750 and only one of the two headlight bulbs would be illuminated at a time, dip or main beam.
Lots of people changed the wiring so both bulbs lit when you switched to main beam effectively a permanent headlight flash.
Personally I was not too sure it wouldn’t harm the wiring, even if it did dramatically improve the light output on unlit roads
This was my line of thought.
Google informs me that this bike has an LED array in its headlamp and for an entire side to stop working - sounds more like an ordinary electrical fault rather than the LED array being broken. Usually as LEDs wear out they will stop working individually and the MOT allows for a certain %. But this shouldn’t be happening to a 3 year old bike and even if it does, would be more likely for the ‘always on’ dip side. But how to fix it? I wouldn’t rush to full replacement I would be heading to a dealership and have the fault traced. Fuse perhaps or a broken solder join/wire - loose connection come apart, maybe. Faulty switch on the handlebar could be the cause too.
Edited by Gerontious
  • Like 3
when did you suddenly decide to trust google?
as a work site that has many of them plus many electric engineers that say the same.
to put a actual truth to this depending on how many units leds are linked into a unit, quality and use case.
units can go at any time and to what grade goes or degrades. While sections or partially is as about as accurate as "whats the length of a piece of string" they die at anytime and its tough sh1t...
When it lead me to a review on these bikes that answered the question I was asking. "Does the 2020 Z900 have LED lights?"
I asked that and one of the top results was from MCN.  And one can usually trust what MCN has to say about specifications. especially when multiple other sources are saying the exact same thing.
This is where google comes in handy.
I own a bike with LED lights and I know that if an entire array stops working then the problem is much more likely to be a general electrical problem than a fault in the array itself. 9/10 it will be the switch at the handlebar. And as the cost of a new headlamp is somewhat prohibitive, its generally a good idea to rule out the simple causes first rather than jump straight to a full replacement. You are going to seem a bit dumb if you buy a brand new headlamp and that doesn't work either because the problem is actually a faulty switch.
  • Like 2
