geofferz Posted March 14, 2024 Posted March 14, 2024 33 minutes ago, keith1200rs said: Traction control can control the brakes and throttle. It can't help if you simply take a corner too fast. Not brakes - that's abs. Tc kills power to the rear tyre when it senses a slip using the wheel speed sensor vs the front. Happens loads on track very successfully. Quote
RideWithStyles Posted March 14, 2024 Posted March 14, 2024 (edited) On 14/03/2024 at 10:33, geofferz said: Not brakes - that's abs. Tc kills power to the rear tyre when it senses a slip using the wheel speed sensor vs the front. Happens loads on track very successfully. tec Edited May 15, 2024 by RideWithStyles Quote
S-Westerly Posted March 14, 2024 Posted March 14, 2024 Reckon I can see how if you are pulling out from a junction with a brand new tyre you could lose it. Combination of tyre with less grip than expected, a bit of a lean and even a relatively gentle tweak of the throttle the tyre could just slide out from underneath particularly if there were road markings or a damp road or gravel. Ouch. Quote
geofferz Posted March 14, 2024 Posted March 14, 2024 12 minutes ago, S-Westerly said: Reckon I can see how if you are pulling out from a junction with a brand new tyre you could lose it. Combination of tyre with less grip than expected, a bit of a lean and even a relatively gentle tweak of the throttle the tyre could just slide out from underneath particularly if there were road markings or a damp road or gravel. Ouch. Yep! 1 Quote
