Edlored Posted August 19, 2024 Posted August 19, 2024 Hi, I've got a GSX600F, when I turn the ignition key I've no power even when I try to jump start it the battery is new. Thanks in advance Quote
husoi Posted August 19, 2024 Posted August 19, 2024 Kill switch? The red big switch on the handle bar Quote
RideWithStyles Posted August 19, 2024 Posted August 19, 2024 You’ll need power to supply. over husoi suggestion this the Battery fitted (correct size/power) with the correct polarity? Fitted tightly enough? Blown a fuse or two? Quote
Nick the wanderer Posted August 20, 2024 Posted August 20, 2024 Hi, welcome. Yeah as above start checking connections and fuses, good luck! Quote
Simon Davey Posted August 20, 2024 Posted August 20, 2024 @RideWithStyles I mentioned their name, because unless you know that you have to click "follow", then they won't get notification that they have replies. This way, they will get a notice that they've ben mentioned in the thread. Most forums will give you an automatic follow if you start a thread. I blame @Stu, but don't tell him Quote
AstronautNinja Posted August 20, 2024 Posted August 20, 2024 32 minutes ago, Simon Davey said: @RideWithStyles I mentioned their name, because unless you know that you have to click "follow", then they won't get notification that they have replies. This way, they will get a notice that they've ben mentioned in the thread. Most forums will give you an automatic follow if you start a thread. I blame @Stu, but don't tell him I've actually moarked the entire forum as read, now I only see the new threads under "unread" so its pretty easy to keep up with new posts etc. Bloody Stu cant get the staff these days haha Quote
RideWithStyles Posted August 20, 2024 Posted August 20, 2024 (edited) 1 hour ago, AstronautNinja said: I've actually moarked the entire forum as read, now I only see the new threads under "unread" so its pretty easy to keep up with new posts etc. Bloody Stu cant get the staff these days haha Thats how I do it too, far easier. i don’t blame Stu , there are other ways/options to do it and they are in the menu/corner you just need to be bothered to see them. Edited August 20, 2024 by RideWithStyles Quote
Simon Davey Posted August 20, 2024 Posted August 20, 2024 1 hour ago, AstronautNinja said: I've actually moarked the entire forum as read, now I only see the new threads under "unread" so its pretty easy to keep up with new posts etc. Bloody Stu cant get the staff these days haha 10 minutes ago, RideWithStyles said: Thats how I do it too, far easier. i don’t blame Stu , there are other ways/options to do it and they are in the menu/corner you just need to be bothered to see them. Me too guys, just a quick scroll down looking for orange.... RWS, I was just having a chuckle with Stu, the software is the software, how it works is working well. 1 Quote
AstronautNinja Posted August 20, 2024 Posted August 20, 2024 15 minutes ago, Simon Davey said: RWS, I was just having a chuckle with Stu All in good jest ,) Quote
husoi Posted August 20, 2024 Posted August 20, 2024 Yes @Simon Davey blame the users Typical it managers 1 Quote
Stu Posted August 20, 2024 Posted August 20, 2024 3 hours ago, Simon Davey said: I blame @Stu, but don't tell him I won't tell him either......... 4 Quote
Bender Posted August 20, 2024 Posted August 20, 2024 1 hour ago, husoi said: Yes @Simon Davey blame the users Typical it managers To be fair he's right 1 Quote
