onesea Posted March 7 Posted March 7 Does anyone have any experience? https://www.diy.com/departments/outdoor-garden/garden-power-tools/pressure-washers/DIY780421.cat?Corded%2Fcordless=Cordless Are they worth it or is a garden spray better? https://www.diy.com/departments/outdoor-garden/garden-power-tools/pressure-washers/DIY780421.cat?Corded%2Fcordless=Cordless Tempted by electric for light jobs. 1 Quote
Simon Davey Posted March 7 Posted March 7 Everything on the B&Q page you listed wasn't available in store. Although they're part of B&Q, Screwfix do this, which is tempting as I have a couple of the Titan batteries already. 1 Quote
Tiggie Posted March 7 Posted March 7 Seen a few being used on various youtube videos. From what I can see they are good for washing cars, bikes etc but don't expect them to be up to patio flags etc. Never used one myself though. Quote
billysugger Posted March 7 Posted March 7 They are powerful enough to cut into tarmac on the narrowest setting, but absolutely great for cleaning your bike 1 Quote
RAYK47 Posted March 14 Posted March 14 what do you do about water then? do you still have to run a hose or can it use a bucket? Quote
Simon Davey Posted March 14 Posted March 14 17 minutes ago, RAYK47 said: what do you do about water then? do you still have to run a hose or can it use a bucket? Most do both. 1 Quote
Mold Posted March 14 Posted March 14 I have one, it was cheap enough, I think I paid around £17 - £20 for it. It has several nozzles for different spray types but I've never changed the standard one, it also has a small bottle that you can fill with washing up liquid so it sprays soapy water. It came with two batteries. I have a water barrel and I run it from there but a bucket would do, just weigh down the end of the water pipe so it doesn't float. The jet stream is adequate but it's not powerful. As for are they worth it, well £20 isn't a great deal, and for me it's a lot more convenient than using a hose and I have the added bonus of the batteries match some of my power tools! 3 3 Quote
onesea Posted March 23 Author Posted March 23 Well maybe afew days ago I got click happy Not a named brand but quite predictably Temu special: This one… @. £22.89 What can I say after one days use…. No it won’t remove road grime, it will remove salt sand soil. It’s not going to remove road film, or bring the green out of your decking. However it’s unlikely to have, enough power to get to far into your electrics or bearings, The spray foam bottle gave a reasonable foam. As at this stage I normally give the foam a wipe, so it worked for me. Then it did a good job on the rinse. Of course a 240 jetwash is better, however 2 buckets of water will clean your bike if you don’t have power and a hose. Would a hose attachment with good water pressure be better maybe, you would use allot water. Would I buy a superdooper £150 version I would have to see one working. 1 Quote
daveinlim Posted March 23 Posted March 23 Ive got the worx one. Jet wash is over stateing it's ability. It had enough power to wash the bike but won't remove dirt like a jet wash at a car wash. i use the spray foam bottle to cover in suds then wash the bike and then clean off with a spray again. It's not got anywhere near the power of a mains operated machine but I like that knowing that it's not going to damage electrics. Quote
Capt Sisko Posted April 4 Posted April 4 (edited) I've got a Ryobi one and for light /medium weight stuff it's not bad. Certainly good enough for day to day washing the bike and seeing off the assorted salt & winter crud, but not powerfull enough to blast the patio or the black haze that you get on the back of a car. The 'kit' comes with a hose to suck water from a bucket, and it does work, but I usually attach it to the mains water hose as it seems to produce more pressure out of the pointy end that way. The battery last more than enough for several, wet, wash & rince cycles. https://www.amazon.co.uk/Ryobi-RY18PW22A-0-18V-ONE-Cordless/dp/B08JM2XZGX?source=ps-sl-shoppingads-lpcontext&ref_=fplfs&smid=A3P5ROKL5A1OLE&gQT=1&th=1 I still have 'proper' jet wash but only use this on the bike sparingly and then on the parts like the front of the engine & cylinder cooling fins that catch the brunt of the road cr*p and that has been baked dry as the bike didn't get wash after the previous mucky ride. Bottom line, if / when it dies will I buy another battery powered one, probably. Edited Friday at 16:25 by Capt Sisko 1 Quote
JRH Posted April 6 Posted April 6 @Capt Sisko I have that one. As I have a Ryobi drill and impact driver with 3 batteries it made sense to get that one. Use on the bike and car to apply foam but as you say not enough umph to clean a patio. 2 Quote
Davidtav Posted Friday at 13:41 Posted Friday at 13:41 I was wondering about these. Slightly off topic. But for my boat. Which is now on a mooring. So could I put the hose in the sea and jet wash the decks with sea water? I’ve been wondering this. Quote
billysugger Posted Friday at 14:42 Posted Friday at 14:42 Not sure you'd want to run saltwater through one Quote
Capt Sisko Posted Friday at 16:44 Posted Friday at 16:44 I don't see why it shouldn't work. They are designed to work doing a wet job and on the Ryobi one I've got the battery is in a sealed up box. Obviously salt water is far more corrosive that fresh, but they're designed to accept chemicals, i.e. snow foams and as with all these types of thing, there's so littal 'metal' in them anyway. If you think the salt water might affect it, just run some fresh through it as the last thing you do. Given that Boat is also short for 'Break Out Another Thousand', a hundred quid for a cordless jetwash from a known make is quite cheap. Quote
onesea Posted Friday at 21:27 Author Posted Friday at 21:27 7 hours ago, Davidtav said: I was wondering about these. Slightly off topic. But for my boat. Which is now on a mooring. So could I put the hose in the sea and jet wash the decks with sea water? I’ve been wondering this. Reading above and having tried mine on fresh water on the boat. I am happy with my £20 version for the boat. My plan is to take out 10 or 20 Ltrs of water which is enough for a fresh wash after salt. 1 Quote
