MonkeyKnuckle Posted February 26, 2009 Share Posted February 26, 2009 Hey, just a quick question. When I got my bike back from the garage I noticed there was some grease/oil on the fairing by the side stand.(Only picture I have, just to show where I mean. Don't have any pictures of the oil/grease. It was in the small area behind the stand.)http://i114.photobucket.com/albums/n245/MonkeyKnuckle/Bike003.jpgAs you can tell I'm not sure if it was oil or grease. I think it was probably grease as it was quite sticky and a bugger to get off. Anway, I noticed it's started to come back so must be dripping off somewhere. Is there anything around that area that usually has grease dripping off? Maybe coming off the chain? Thanks for any help. Quote Link to comment Share on other sites More sharing options...
Korben Posted February 26, 2009 Share Posted February 26, 2009 My Hornet gets a good build up of Chain Lube around that area... Could just be that!! Quote Link to comment Share on other sites More sharing options...
Voodoo Posted February 26, 2009 Share Posted February 26, 2009 Its off your chain, mines always caked in oil! Quote Link to comment Share on other sites More sharing options...
Fozzie Posted February 26, 2009 Share Posted February 26, 2009 Didnt you get a new exhaust recently? Might have not been fitted on fully sealed up. Small gap might be allowing fluids building up in the exhaust to settle after use and drip out. Had the same thing on my last bike. Did nothing but cause a mess. I suspect its nothing bad because my bike had the same thing in the same place too.Hope that helps Quote Link to comment Share on other sites More sharing options...
MonkeyKnuckle Posted February 26, 2009 Author Share Posted February 26, 2009 Thanks guys, hoping it was something innocent. Thought I'd make sure because I'm gonna be going for a long ride this weekend. Quote Link to comment Share on other sites More sharing options...
cyberwolf Posted February 26, 2009 Share Posted February 26, 2009 Didnt you get a new exhaust recently? Might have not been fitted on fully sealed up. Small gap might be allowing fluids building up in the exhaust to settle after use and drip out. Had the same thing on my last bike. Did nothing but cause a mess. I suspect its nothing bad because my bike had the same thing in the same place too.Hope that helps his exhaust/pipes well be on the right side of bike and if crap like that was coming from exhaust it prob means its time to spend loads of money on your engine its just oil of your chain i use wd40 to clean it of my bike all bikes with a chain have same problom Quote Link to comment Share on other sites More sharing options...
Guest Posted February 26, 2009 Share Posted February 26, 2009 could be chain lube or they could have evenlubed your side stand pivot for ya Quote Link to comment Share on other sites More sharing options...
collier32 Posted February 26, 2009 Share Posted February 26, 2009 there is a black plastic cover over the front sprocket chain lube builds up in there untill it runs out you can un-bolt it and clean it out its dead simple to do Quote Link to comment Share on other sites More sharing options...
Fozzie Posted February 26, 2009 Share Posted February 26, 2009 Didnt you get a new exhaust recently? Might have not been fitted on fully sealed up. Small gap might be allowing fluids building up in the exhaust to settle after use and drip out. Had the same thing on my last bike. Did nothing but cause a mess. I suspect its nothing bad because my bike had the same thing in the same place too.Hope that helps his exhaust/pipes well be on the right side of bike and if crap like that was coming from exhaust it prob means its time to spend loads of money on your engine its just oil of your chain i use wd40 to clean it of my bike all bikes with a chain have same problom ....Carbon build up along with tiny bits of fuel that get kicked out into the exhaust and sometimes cause a backfire??? Cause a blackish, thin fluid.. Quote Link to comment Share on other sites More sharing options...
MonkeyKnuckle Posted February 26, 2009 Author Share Posted February 26, 2009 Thanks again guys. Looks like the garage must have given my chain a bit of a lubing, which was nice of them. They cleaned it as well. Need to take it to them more often. Quote Link to comment Share on other sites More sharing options...
Stu Posted February 27, 2009 Share Posted February 27, 2009 remove your sprocket cover and give it a good clean inside while its off check out your clutch push rod seal that could be whats leaking and mixing with chain lube thats inside the sprocket cover then running out i have just replaced my clutch push rod seal for the same reason road salt and grit gets thrown on to the push rod then in to the seal when you use the clutch which destroys the seal Quote Link to comment Share on other sites More sharing options...
Guest Posted February 27, 2009 Share Posted February 27, 2009 destroys the seal i've blown a seal before Quote Link to comment Share on other sites More sharing options...
TC Posted February 27, 2009 Share Posted February 27, 2009 Thanks guys, hoping it was something innocent. Thought I'd make sure because I'm gonna be going for a long ride this weekend. Not going to Tag stonehenge by anychance Quote Link to comment Share on other sites More sharing options...
MonkeyKnuckle Posted February 27, 2009 Author Share Posted February 27, 2009 Thanks guys, hoping it was something innocent. Thought I'd make sure because I'm gonna be going for a long ride this weekend. Not going to Tag stonehenge by anychance 'Fraid not. I was going to do it last week but didn't have the time in the end. And I can't do it this weekend, next weekend or the following weekend so someone probably would have tagged it by then. Quote Link to comment Share on other sites More sharing options...
