fazerboy Posted July 31, 2011 Share Posted July 31, 2011 my 1000 has started playing up...grr get to about 80 some times more sometimes less around 5000 6000 revs,its stuttering and sort of cuts out until at a lower speed and then picks up only to do the same thin again..off the france at end of month so need it sorting...any ideas? Quote Link to comment Share on other sites More sharing options...
Colin the Bear Posted July 31, 2011 Share Posted July 31, 2011 Fuel starvation Quote Link to comment Share on other sites More sharing options...
fazerboy Posted July 31, 2011 Author Share Posted July 31, 2011 enlighten me please mr bear...if fuels starvation,how come at the same revs all the time and not higher or lower or not totally cutting out?cheers Quote Link to comment Share on other sites More sharing options...
Colin the Bear Posted July 31, 2011 Share Posted July 31, 2011 The faster the engine revs , the more fuel it draws. You have enough getting through for 5k but no more. Could be a partialy blocked in line filter or kinked fuel line. Quote Link to comment Share on other sites More sharing options...
Bogof Posted July 31, 2011 Share Posted July 31, 2011 The faster the engine revs , the more fuel it draws. You have enough getting through for 5k but no more. Could be a partialy blocked in line filter or kinked fuel line. I have the same issue with a CBR400. It won't go above 8k revs. The airbox is broken and doesn't quite connect on 2 carbs, would that cause it? Quote Link to comment Share on other sites More sharing options...
Tango Posted July 31, 2011 Share Posted July 31, 2011 The faster the engine revs , the more fuel it draws. You have enough getting through for 5k but no more. Could be a partialy blocked in line filter or kinked fuel line. Or blocked fuel tank breather. Quote Link to comment Share on other sites More sharing options...
fazerboy Posted July 31, 2011 Author Share Posted July 31, 2011 Cheers....keep em coming please.... Quote Link to comment Share on other sites More sharing options...
7vwh Posted July 31, 2011 Share Posted July 31, 2011 check there's nothing blocking the air intake, it's just forward of the battery. Quote Link to comment Share on other sites More sharing options...
Tango Posted August 1, 2011 Share Posted August 1, 2011 Clogged air filter......not the most likely cause...but easy to check.Is it only in top gear that this is happening.....or is it 5k plus in all gears? Quote Link to comment Share on other sites More sharing options...
megawatt Posted August 1, 2011 Share Posted August 1, 2011 Don,t think anything to do with fuel. Maybe a switch in the ignition circuit that is vibrating.? Wd all switches and test em? Quote Link to comment Share on other sites More sharing options...
rennie Posted August 1, 2011 Share Posted August 1, 2011 I will bet it's none of the above! It will be the exup valve not working correctly!it opens at around 6000 revs. Quote Link to comment Share on other sites More sharing options...
7vwh Posted August 1, 2011 Share Posted August 1, 2011 if the exup isn't working properly then the tacho bounces up to 7k and back to let you know. Quote Link to comment Share on other sites More sharing options...
rennie Posted August 1, 2011 Share Posted August 1, 2011 mine doesn't! the oil light comes on! Quote Link to comment Share on other sites More sharing options...
fazerboy Posted August 1, 2011 Author Share Posted August 1, 2011 It happens at all gears at around 5/6000 revs it doesnt go to 7000 and come back down...i actually had it too 100 but I wound on a little bit more and wosh down it came again.ive not had it out much latley...im wounderin if I got a mouse in the airbox or something as ive had the seat off and left it Quote Link to comment Share on other sites More sharing options...
Tango Posted August 1, 2011 Share Posted August 1, 2011 It happens at all gears at around 5/6000 revs it doesnt go to 7000 and come back down...i actually had it too 100 but I wound on a little bit more and wosh down it came again.ive not had it out much latley...im wounderin if I got a mouse in the airbox or something as ive had the seat off and left itYeah...check your airbox and filter. Could have any manner of stuff in there!! Quote Link to comment Share on other sites More sharing options...
TC Posted August 1, 2011 Share Posted August 1, 2011 Have you put any Comms/sat nav equipment under the seat.There is a lovely little compartment under the seat to fit it all into. However the whole compartment has to be left empty to provide enough air flow for the intake. Quote Link to comment Share on other sites More sharing options...
fazerboy Posted August 1, 2011 Author Share Posted August 1, 2011 Well funny you should say that....i just disconnected the hardwire for a tomtom rider and removed some wires destined to be used on some heated grips...but ive attatched a cigarette lighter attatchment....would this have affected it? Quote Link to comment Share on other sites More sharing options...
7vwh Posted August 1, 2011 Share Posted August 1, 2011 The electrical side of things shouldn't have made any difference, where you put the cig ligher attachment might have. Here's a couple of pics of mine....The opening is the intake to the air filterhttp://i229.photobucket.com/albums/ee79/7vwh/stuff/CIMG3245.jpgFrom above it looks like a small storage space, anything stuffed down there will affect the intake.http://i229.photobucket.com/albums/ee79/7vwh/stuff/CIMG3246.jpg Quote Link to comment Share on other sites More sharing options...
TC Posted August 1, 2011 Share Posted August 1, 2011 Thats the compartment Quote Link to comment Share on other sites More sharing options...
fazerboy Posted August 1, 2011 Author Share Posted August 1, 2011 Much tidier than mine Quote Link to comment Share on other sites More sharing options...
Colin the Bear Posted August 1, 2011 Share Posted August 1, 2011 You have an untidy underseat compartment.....and here's me thinking you were a bloke Quote Link to comment Share on other sites More sharing options...
7vwh Posted August 1, 2011 Share Posted August 1, 2011 this is the untidy end.......http://i229.photobucket.com/albums/ee79/7vwh/stuff/CIMG3248.jpg Quote Link to comment Share on other sites More sharing options...
Colin the Bear Posted August 1, 2011 Share Posted August 1, 2011 Is that a video cassette and a packet of condoms? Quote Link to comment Share on other sites More sharing options...
TC Posted August 1, 2011 Share Posted August 1, 2011 Much tidier than mine Then clear it out and go for a blast.note:- The air intake is towards the front end of the battery Quote Link to comment Share on other sites More sharing options...
fazerboy Posted August 2, 2011 Author Share Posted August 2, 2011 Well got under the seat and cig lighter was in the air box appateur...moved it and low n behold woooosh off it went..so popped over too jordans and put it on the dyno...a healthy 118 bhp and 156 in fith...im happy. Cheers all.... Quote Link to comment Share on other sites More sharing options...
