Katie Posted April 16, 2012 Posted April 16, 2012 Does anyone know how to do this? I don't have the manual and it's driving me nuts as it's a random amount so I can't quickly work out what time it really is.Thanks It's a 2007 if that makes any difference. Quote
dimmers Posted April 16, 2012 Posted April 16, 2012 try holding down any 'select' buttons for more than 2 seconds, might work. Quote
RiffmasterII Posted April 16, 2012 Posted April 16, 2012 If its got two buttons hold them down at the same time to enter the set up menu Quote
Tango Posted April 16, 2012 Posted April 16, 2012 I am absolutely no use to you whatsoever here Katie....but when I tried doing this on my Speed Four I ended up changing the Speedo to Km/H and the temp readout to Fahrenheit...... Have fun..... Quote
Katie Posted April 16, 2012 Author Posted April 16, 2012 Thanks everyone Tango I know exactly what you mean. One of the centrifuges at work has been in German for the last couple of years after I tried to set a new protocol on it! I've tried pressing the two buttong but it's like they don't do anything. They are squashy bits of rubber rather than buttons and you don't seem to be able to press them properly. Here's link to one for sale on ebay so you can see what I meanhttp://www.ebay.co.uk/itm/Speedo-Speedometer-Clock-Unit-Tacho-Kawasaki-ZZR600-ZX600-E5-1997-Ninja-EAB9-/260929347157?pt=UK_Motorcycle_Parts&hash=item3cc099de55 Quote
RiffmasterII Posted April 16, 2012 Posted April 16, 2012 If that one has got the right time on it why dont you buy that and replace yours??Looks like there an Hour and minute button on it, have you tried just holding them in until the numbers start to flash? Quote
Katie Posted April 16, 2012 Author Posted April 16, 2012 If that one has got the right time on it why dont you buy that and replace yours?? Ha HaI've done it!! Needed to prod them with a key, fingers just not enough Quote
fredc Posted April 16, 2012 Posted April 16, 2012 copied from another forum1. Turn ignition on.2. Push the Clock/Temp button to display the clock.3. Push the Clock/Temp button for two seconds or more and both the hour and minute displays will start flashing.4. Again push the Clock/Temp button and only the hour will flash. Push the Odo/Trip button to advance the hour.5. Push the Clock/Temp button to then stop the hours from flashing and start the minutes flashing. Push the Odo/Trip button to advance the minutes.6. When both the hours and minutes are set, push Clock/Temp once more, then both will flash once again. You're done.7. To exit the set mode, press Trip/Odo and the time will stop flashing and the clock will continue normally. Quote
Colin the Bear Posted April 17, 2012 Posted April 17, 2012 Cover display with gaffer tape and buy a watch Quote
Natsun85 Posted August 11, 2022 Posted August 11, 2022 (edited) Yep I just figured it out for the zzr. Hold the clock/temp for a couple of seconds till the whole time flashes. Press the clock/temp one more time to select the hour or twice for the minutes. When you have the desired flashing press the odo/trip to change the numbers on the clock. Edited August 11, 2022 by Natsun85 Quote
Jules Posted November 27, 2022 Posted November 27, 2022 Hi can anyone please tell me where I can or may obtain the two clock face grommets that are on my wife’s E7 to enable us to change time. Thx Quote
Old-codger Posted November 27, 2022 Posted November 27, 2022 If you are talking about a ZZR600 E7 and the trip reset rubber grommet it could be this part KNOB,TRIP RESET product number: 920771112 Have a look at the parts diagram to identify the part required Kawasaki ZX600E7 ZZR600 1999 EUROPE UK FR NL FG GR IT NR SD METER(S) - buy original METER(S) spares online (cmsnl.com) Quote
MikeHorton Posted November 27, 2022 Posted November 27, 2022 Any IT expert would have told you to just turn it off and on again Quote
