zedhead Posted May 28, 2012 Posted May 28, 2012 Hi Weird one here. My sons 125cc ebnduro bike will stall when you try to pull away.If the bike is standing still you can rev the nuts of it so i am thinking the carb is getting enough fuel,but drop it into first and release the clutch blurrgh no power and it stalls.This started after replacing the sprockets [same amount of teeth as old sprockets] and cush drive.I have stripped and cleaned the carb twice but that made no difference.If i had hair it would be out now.zedhead Quote
eastanglianbiker Posted May 28, 2012 Posted May 28, 2012 changing the chain and sprockets would not cause this problem to arise,when you have been cleaning the carb out have you moved the mixture screw on the side of the carb at all or damaged the reed valve if it has one? and are you sure it hasnt run out of petrol? Quote
Tango Posted May 28, 2012 Posted May 28, 2012 If it'll rev off load but stalls under load I'd be looking at the spark and the plug.....just a thought.... Quote
zedhead Posted May 28, 2012 Author Posted May 28, 2012 I didnt think the sprockets had anything to do with it but it helps to list the things youve done prior to the problem arising. The only screw i have moved when cleaning the carbs was the pilot screw,and i put it back in the same number of turns that came out.Also i only cleaned the carbs after this problem arose.Petrol tank full fuel petcock working fine and carb bowl always has petrol.Checked spark plug-fineBoth front and rear wheels turning freely neither brake binding.Bike revs throughout the range smoothly and flawlesly.Sit on the bike release clutch and advance throttle bl**@y thing stalls. Quote
Guest Hodgy Posted May 28, 2012 Posted May 28, 2012 Have you checked the compression? just a thought Quote
Tango Posted May 28, 2012 Posted May 28, 2012 Have you got a nice strong spark?......if it's weak the bike will bog down and stall when you put it under load. Do you have a spare plug you could swap it with just in case? What colour is the plug? Clogged air filter? Seems a bit strange that this happened when you changed the chain and sprockets....but weird things happen sometimes..... Quote
Colin the Bear Posted May 28, 2012 Posted May 28, 2012 Have you trapped something changing sprockets.How does it stall, does it just cut out or splutter and die, sidestand switch? , clutch switch? Quote
Tango Posted May 28, 2012 Posted May 28, 2012 Good Call Colin......sidestand switch may have taken a knock when changing the chain and sprockets..... Quote
Colin the Bear Posted May 28, 2012 Posted May 28, 2012 I just post sidestand switch to all questions and am right about 25% Quote
zedhead Posted June 2, 2012 Author Posted June 2, 2012 Ok finally got back to the bike. I checked the plug again getting good spark,checked fuel tank breather pipe,checked everything i could ,associated with things i had changed ie:sprockets to the functioning of the choke and throttle cables after removing and cleaning the carbs...phew!!.Started bike ,runs perfectly throught rev range on idle,pulled away and it ran smooth with only a couple of dips which quickly disappeared. Bike now runs smooth as ever!!!!!! and i have no idea how it got fixed .Will test run it more over the weekend and fingers crossed it's sorted.Thanks to everyone who suggested ideas much appreciated.zedhead Quote
Colin the Bear Posted June 2, 2012 Posted June 2, 2012 You must have found the right position for your mouth. This is critical for quick starts That and the petrol fairy Quote
zedhead Posted June 7, 2012 Author Posted June 7, 2012 Ok first off apologies for the sporadic nature of these posts,other commitments mean i cant always get to the bike .Took it out for a test worked fine did about three miles got bike nice and warmed up.That's when it started again!!!. Bike revs freely throught the range in neutral ,but pop it into gear and it struggles to pull away. All you can do is pull clutch in and try againand again with the same result, no power to pull away. I have done an internet search for this problem and most of the answers lie in one of two camps..Carbs or Sparkplug. I have cleaned the former twice and the latter is in good condition [only done 10-20 miles on it since new] and gives a decent spark.On the subject of spark the battery does seem to lose charge easily if the bike is not used much. Not being used to a 125 for a long time could the battery condition affect the performance of a small cc bike?. I may be clutching at straws but ... zedhead Quote
Joeman Posted June 7, 2012 Posted June 7, 2012 What bike is it? if it revs freely in Neutral, how does it rev in gear with the back wheel off the ground? Quote
eastanglianbiker Posted June 7, 2012 Posted June 7, 2012 yes battery condition could affect the way the bike runs also the problem could be with spark plug i have just had similar problem with my bike started fine when cold ran fine but wouldnt restart when hot and was pig to keep running new plugs solved the issue.how old is the battery on your bike and have you checked charging rate Quote
Colin the Bear Posted June 7, 2012 Posted June 7, 2012 All electricals are routed through battery. You wouldn't believe the problems a duff battery can generate. If you suspect the battery, and considering the price for a 125, I'd replace it. Did these problems start after fitting a new plug? New ones can be duff. Try another, if it's not that you have a spare Quote
TC Posted June 8, 2012 Posted June 8, 2012 Have you checked the compression? just a thought  I'm with Hodgy here, sounds like you are losing compression when the engine is under load, Quote
Voodoo Posted June 8, 2012 Posted June 8, 2012 Change the spark plug, they don't cost much and it will eliminate that as the problem. Quote
Colin the Bear Posted June 9, 2012 Posted June 9, 2012 Have you checked the compression? just a thought  I'm with Hodgy here, sounds like you are losing compression when the engine is under load, I can't see how a loss of compression would give an intermittent fault Quote
Guest Hodgy Posted June 9, 2012 Posted June 9, 2012 Have you checked the compression? just a thought  I'm with Hodgy here, sounds like you are losing compression when the engine is under load, I can't see how a loss of compression would give an intermittent fault Maybe I miss-read the op, I didn't spot it was intermittent, I thought it was whenever he was setting off? You are right though, low compression can't be intermittant Quote
OhJay Posted June 9, 2012 Posted June 9, 2012 Not likely to be the clutch is it? Something snagging/clogging/dirty in there? Quote
Joeman Posted June 9, 2012 Posted June 9, 2012 Not likely to be the clutch is it? Something snagging/clogging/dirty in there? That's why the OP should try lifting the back wheel, kicking it into gear, and seeing if it stalls then.Might be low on G-box oil and seizing when it gets warm Quote
pointblank0 Posted June 9, 2012 Posted June 9, 2012 From what I have heard, I would say that the cluth cable is either worn or too loose, just a thought. It seems that the engine runs fine in neutral, but when taking off, it stalls. I reckon it's worth checking, if those friction disks are compressing straight away, the bike will stall like you describe. Does the bike creep forward when in gear and cluth lever pulled right in? Quote
Danny-B- Posted June 14, 2012 Posted June 14, 2012 I smell a faulty side stand switch by a mile ... if the top of the side stand switch is covered in gunk (oil from chain etc) then its shorting out the sidestand switch and causing the engine to cut out ... my old CBR did this when i was in gear and revving about 5000 ... to eliminate the sidestand, take the switch off and short the two wires out ... (could have three, in which case, one is for the dash light) Quote
zedhead Posted June 18, 2012 Author Posted June 18, 2012 Hi again thanks for all the comments on this ongoing problem.As i have been trying to sort this a few things have come to light.1/ The bike from cold pulls away and runs fine.After a couple of minutes riding [maybe 5-10 min at times]. The bike will lose power.When i originally found the problem the bike had already been running, hence the title.2/ The power loss can happen when pulling away or when riding at speed 30mph etc.3/ I have jacked the bike up and ran the bike through the gears up to speed for 5 minutes and no loss of power.! It only appears when the bike is ridden.4/ Spark is good, nice and healthy,there is plenty of petrol. The gearchange is smooth and the cable works fine. Battery is charging and holding charge.There is required amount of oil in the sump.5/ After running the bike and the problem appears i leave it to cool for an hour. When i try again the bike works fine for a few minutes and then the problem is back.6/ The side stand switch suggestion made me think, as this bike has wiring leading from the clutch lever into the loom. I do not know where it goes. I have never had to pull the clutch in to start the bike.I should weather permitting get back to the bike on Wednesday to try again.Thanks again for all the suggestions i will sort this b@**er out!zedhead Quote
Stu Posted June 18, 2012 Posted June 18, 2012 I haven,t re-read the thread again so dont shoot me have you checked the coils? they could be breaking down with heat and load Quote
