BikerMooFromMars Posted July 26, 2013 Posted July 26, 2013 Right, Wallie (RantMachine) is gonna get the arse at me for asking this, but I don't want us to have to cancel our weekend trip to Norfolk because of it, and I like to know my hubby is safe of course Basically his chain is making a real horrible loud metal-scraping noise when he is between changing gears. He has gone thru the Hanyes (which, knowing him Mister Sensible, he would have been pretty thorough), has cleaned and oiled the chain (not Benn-style thankfully! ), checked its tension and there's no evident problem. Apparently it's done it for a little while, and he gets it serviced regularly - thanks to his very short service schedules - and nothing has been picked up by the dealer either. I've noticed it before but think it's getting louder. His next service is very soon anyway - Saturday next week.Would massively appreciate any advice if anyone has any idea what it may be...Ollie is working between 2-10pm today so I may be able to delete this thread before he sees?? Hahaha! Thanks lovelies Quote
acting_strange Posted July 26, 2013 Posted July 26, 2013 Have a look at the rubbing strip on the top of the swing arm near the front sprocket...make sure it has one and that it isnt worn through.. Quote
Joeman Posted July 26, 2013 Posted July 26, 2013 Basically his chain is making a real horrible loud metal-scraping noise when he is between changing gears. So you mean the noise is when he's moving and pulls in the clutch??get him to try riding along and just pull the clutch (without changing gear) to see if its related to the clutch.does he have oil in there?? Quote
acting_strange Posted July 26, 2013 Posted July 26, 2013 Basically his chain is making a real horrible loud metal-scraping noise when he is between changing gears. So you mean the noise is when he's moving and pulls in the clutch??get him to try riding along and just pull the clutch (without changing gear) to see if its related to the clutch.does he have oil in there?? But surely if it was the clutch he could check it whilst not moving?..The clutch is spinning all the time the engine is running..just not disengaged until the lever is pulled in? Quote
Joeman Posted July 26, 2013 Posted July 26, 2013 whereas the chain is spinning all of the time the bike is moving, so no reason to only make a noise from the chain between gear changes... Quote
acting_strange Posted July 26, 2013 Posted July 26, 2013 whereas the chain is spinning all of the time the bike is moving, so no reason to only make a noise from the chain between gear changes... Not quite....when you pull the clutch in the chain changes from drive to over run so instead of pulling using the front sprocket it is being pushed by the rear sprocket... Quote
Tango Posted July 26, 2013 Posted July 26, 2013 Not really helping guys!Is it during up changes or down changes or both?.......and does it's frequency change depending on what speed he's doing? Quote
Guest Hodgy Posted July 26, 2013 Posted July 26, 2013 Check the sprocket carrier bearing!If he has a center stand put the bike on it and whilst turning the back wheel see if you can wobble the rear sprocket, be very careful not to trap your fingers!!Hope you get it sorted Quote
acting_strange Posted July 26, 2013 Posted July 26, 2013 Not really helping guys!Is it during up changes or down changes or both?.......and does it's frequency change depending on what speed he's doing? I'm sorry but I disagree Bob....working out what the chain is doing and when could be really useful...but it's ok...I'll just stop posting... Quote
Joeman Posted July 26, 2013 Posted July 26, 2013 Not really helping guys!Is it during up changes or down changes or both?.......and does it's frequency change depending on what speed he's doing? This ones all yours then... good luck! Quote
mealexme Posted July 26, 2013 Posted July 26, 2013 it sounds like a loose chain slapping on the swing arm to me. I know you said he checked the tension, but what is it at at the moment?chains may have tight spots, so it's best to check the tension, rotate the wheel and check it again, rotate and check, rotate and check. that way you will find the high points and low points of the chain. ideally you should set the tension at it's tightest point to stop the chain snapping (which is rare, so don't worry about this) or wearing faster. with the tension set, if at it's loosest point, the chain hits the bottom of the swing arm, you may need a new chain. Quote
Chrissb6 Posted July 26, 2013 Posted July 26, 2013 Hi, if he's checked the chain tension and its all lubed up that should eliminate that part. A horrid noise between gear changes, look for the easiest first. Chain routing, cushion drive rubbers and rear wheel bearings next. from there its the clutch, which l suspect, it might be a broken clutch plate. Really hope l'm wrong. and that its something simple. If it don't sound right it probably isn't stay safe. Quote
BikerMooFromMars Posted July 26, 2013 Author Posted July 26, 2013 Thanks so much for all your help lovelies. Maybe will just show Ollie this thread and accept my fate of huffs and moaning! Quote
Stu Posted July 26, 2013 Posted July 26, 2013 and give him a big slap from us for not asking earlier Quote
Tango Posted July 26, 2013 Posted July 26, 2013 When are you heading up to your mum's place Moo?........I could pop round and take a look in the morning if you want..... Quote
BikerMooFromMars Posted July 26, 2013 Author Posted July 26, 2013 When are you heading up to your mum's place Moo?........I could pop round and take a look in the morning if you want..... Before the rain we hope (which is scheduled for 11am accd to BBC weather)! V kind of you - but only if you don't mind and wouldn't rater have a lie in! Ollie says we need some tools that we don't have for it he thinks - which we can PM you with later, (save you having to bring lotsa stuff). He's out tonight at a comedy club straight from work so can't talk to him about it but 99.9% sure he'd say "yes please" too! Quote
Tango Posted July 26, 2013 Posted July 26, 2013 I can get round for about 9 ish if that would help? Quote
BikerMooFromMars Posted July 27, 2013 Author Posted July 27, 2013 Thanks so much Bonnie and Tango x Quote
Tiggie Posted July 27, 2013 Posted July 27, 2013 hope it gets sorted for you, sounds very much like he has been doing too much counter-steering Quote
eastanglianbiker Posted July 27, 2013 Posted July 27, 2013 come on then what was it this time ??????? Quote
