Stu Posted December 5, 2015 Posted December 5, 2015 Its miles easier dropping the motor I wish I had dropped mine to be honest but I have lost all enthusiasm when you get yours remapped let them know you have changed the stat to a cooler one as they will need to get it up to temperature so its running on the hot map otherwise the readings will be way off and it will be a waste of time and money! you also need to find out when your hot map comes in and make sure the bike stays above that temp its usually around about 75°c if with the new stat its not above that then you will be loosing power and not running on the custom map that the power commander is set up for I doubt you will have a problem but its something to be aware of Quote
cockercas Posted December 5, 2015 Author Posted December 5, 2015 Bloody good point. I never thorght of telling them.Tbf ive done a day on the new stat.Still runs hot but not as hot as before. Still around 100°c.Thats the fluid temp as it comes out the engine. Ive been thinking about fitting a sensor after the rad. Quote
cockercas Posted December 5, 2015 Author Posted December 5, 2015 A lad who used to race a cbr600rr told me he removed some fins of the impellor in the pump. I think he said 3 so it was still balanced and he said that made his cooler.Not sure, but if i can get a cheap impellor i might give it ago if im still running hot. Quote
Stu Posted December 5, 2015 Posted December 5, 2015 to be honest I think you are worrying too much 90 - 100 degrees when giving it loads on a track is a good temp as long as it stays below about 110 you fine Quote
cockercas Posted December 5, 2015 Author Posted December 5, 2015 Il stick some tape over it lol. Quote
cockercas Posted December 6, 2015 Author Posted December 6, 2015 Goodbye pair valve. Im deleting it.Looked at buying the blanking plates but made my own insted.This is the pair valve.http://i269.photobucket.com/albums/jj44/vtrdonk/20151205_191450_zps4d60qpgr.jpgOne home made plate.http://i269.photobucket.com/albums/jj44/vtrdonk/20151206_135150_zpsz8cuviu7.jpgTwo.http://i269.photobucket.com/albums/jj44/vtrdonk/20151206_142352_zpskdoof3aa.jpgDidnt have any high temp paint so...http://i269.photobucket.com/albums/jj44/vtrdonk/20151206_142509_zpsdibbx928.jpg Quote
Stu Posted December 6, 2015 Posted December 6, 2015 did you make them out of steel or alloy? I have some alloy plate to make some but I can't be arsed to do them Quote
cockercas Posted December 6, 2015 Author Posted December 6, 2015 Steel. I had abit in the garden.Just checked the valves.A couple are abit tight. Quote
cockercas Posted December 13, 2015 Author Posted December 13, 2015 Titanium rear disc bolts.One was stuck fast when i removed the disc so i had to beat it out.they weigh nothing, i bet 3 of the titanium ones weigh as much as one steel one.weight reduction.http://i269.photobucket.com/albums/jj44/vtrdonk/Cars/20151212_144334_zpsvaoqy7tv.jpghttp://i269.photobucket.com/albums/jj44/vtrdonk/Cars/20151213_111536_zps9djkllzp.jpghttp://i269.photobucket.com/albums/jj44/vtrdonk/Cars/20151213_111929_zpsukxxqm5j.jpgThe paint isnt patchy lol its condensation. Quote
cockercas Posted December 14, 2015 Author Posted December 14, 2015 Thanks, engine after a struggle is now in the house. So i can do the valves in the warm. Quote
Guest Posted December 14, 2015 Posted December 14, 2015 Goodbye pair valve. Im deleting it.Looked at buying the blanking plates but made my own insted.This is the pair valve.http://i269.photobucket.com/albums/jj44/vtrdonk/20151205_191450_zps4d60qpgr.jpgOne home made plate.http://i269.photobucket.com/albums/jj44/vtrdonk/20151206_135150_zpsz8cuviu7.jpgTwo.http://i269.photobucket.com/albums/jj44/vtrdonk/20151206_142352_zpskdoof3aa.jpgDidnt have any high temp paint so...http://i269.photobucket.com/albums/jj44/vtrdonk/20151206_142509_zpsdibbx928.jpg Ok I give up. What's a pair valve? Quote
Stu Posted December 14, 2015 Posted December 14, 2015 Ok I give up. What's a pair valve? introduces fresh air in to the exhaust at tick over to weaken the mixture for emmisions tests Quote
Guest Posted December 14, 2015 Posted December 14, 2015 Ok I give up. What's a pair valve? introduces fresh air in to the exhaust at tick over to weaken the mixture for emmisions tests Ah ok.So its another con that they have to do to cheat the emmisions. Like the old power curve flat spot at around 4000 revs on all bikes in the 70's/80's. It just shows what a load of old bollocks these tests and their results are. Quote
cockercas Posted December 14, 2015 Author Posted December 14, 2015 http://i269.photobucket.com/albums/jj44/vtrdonk/Cars/IMG_20151214_184610_zpsbsex3gnn.jpgEngine is in the house, had to kick the boy off the xbox so i could start on the valves.http://i269.photobucket.com/albums/jj44/vtrdonk/Cars/20151214_190721_zpsqd00c5vu.jpgA tiny shimhttp://i269.photobucket.com/albums/jj44/vtrdonk/Cars/20151214_192241_zpsvjxufpfg.jpgGot to phone honda for some new shims in the morning. Quote
Stu Posted December 14, 2015 Posted December 14, 2015 did you try swapping some about to bring other in like I suggested? Quote
Tango Posted December 14, 2015 Posted December 14, 2015 Someone did an Excel spreadsheet that would show which ones could be swapped and list any new ones needed.......but I'm b*ggered if I can remember where I saw it..... Quote
Stu Posted December 14, 2015 Posted December 14, 2015 there is loads about Bob but he has a manual and they are in the manual Quote
cockercas Posted December 14, 2015 Author Posted December 14, 2015 Yes stu.I did the maths and worked out what i needed. I can swap 3 or 4 of them.Need to buy a few though. Hopefully it wont take honda long to get them because they dont carry them on stock. Quote
Stu Posted December 14, 2015 Posted December 14, 2015 excellent its saved you a few quid swapping them then did you try miles kingsport? they usually carry a few!! Quote
Mr Fro Posted December 15, 2015 Posted December 15, 2015 I got mine from wemoto - they carry them as stock for 3 or 4 quid a pop. Quote
cockercas Posted December 15, 2015 Author Posted December 15, 2015 Yes stu, i phoned them yesterday and he said they need to order them.Should be here thursday.6 was £39 from honda. Quote
Stu Posted December 15, 2015 Posted December 15, 2015 That's not too bad Is that exchange or not? If not you will now have some spares! I got some for my TL and they had them in stock Quote
