tuktuk Posted May 5, 2016 Share Posted May 5, 2016 I can never seem to make a decent job of this.Anybody wish to share their tehnique? I have a tub of kerosine but ive been really stingy when applying it not knowing if it will damage any paintwork etc it may get onto. So rather than spraying it on through a bottle i dip a toothbrush into a small pot of it and apply that way? Rinse it down afterwards with wd40 then dry and lube.Watched a video of a guy just spraying the stuff onto the rear sprocket, getting it all over the back wheel and tyre. Granted he made a much better job of cleaning the chain but i wasnt sure wether its safe on paintwork or the tyre(slippy??). Quote Link to comment Share on other sites More sharing options...
megawatt Posted May 5, 2016 Share Posted May 5, 2016 Cover the wheel with a plastic sheet, use a chain cleaning brush and paraffin to degrease the chain. Finish cleaning using brake cleaner sprayed onto a terry towel. Quote Link to comment Share on other sites More sharing options...
GaryJM Posted May 5, 2016 Share Posted May 5, 2016 Or get a bike with belt or shaft drive Protect the rear wheel and then attack it with paraffin.If you can take it off and leave it in a basin of paraffin overnight.Those were my two preferred methods. Quote Link to comment Share on other sites More sharing options...
Joeman Posted May 5, 2016 Share Posted May 5, 2016 Get a big plastic bottle like you get screen wash from halfords in. Chop a slot out of the side big enough to take the chain. You then have an enclosed area to spray the chain cleaner and lube without getting it on your bike/wheel. Quote Link to comment Share on other sites More sharing options...
tuktuk Posted May 5, 2016 Author Share Posted May 5, 2016 Cheers guys, should be able to make a better job of it next time! Quote Link to comment Share on other sites More sharing options...
Bogof Posted May 5, 2016 Share Posted May 5, 2016 Anybody wish to share their tehnique? Fit a Scottoiler Quote Link to comment Share on other sites More sharing options...
Throttled Posted May 5, 2016 Share Posted May 5, 2016 WD40 and a rag works for me. Quote Link to comment Share on other sites More sharing options...
Guest Posted May 6, 2016 Share Posted May 6, 2016 WD40 and a rag works for me.Yeah I use this way.I spray the chain with WD40, then use the brush chain cleaner to mobilize the dirt and then WD40 + rag to get it shiny. Quote Link to comment Share on other sites More sharing options...
Guest Posted May 6, 2016 Share Posted May 6, 2016 I hold some cardboard behind the chain and then give it a good soaking, all the overspray just goes into the cardboard and none on the bike and definitely not the tyre. Quote Link to comment Share on other sites More sharing options...
mozza83 Posted May 7, 2016 Share Posted May 7, 2016 I've started using WD40 and scotchbright pads on the chain then a hose and a rag to rinse the sh*t off. I used to use a piece of cardboard between the chain and the wheel when cleaning which kept the wheel cleaner but now I just soak the wheel with WD40 after and it cleans up real good very easily. Absolutely love WD40, i use it for everything.Sent from my Nexus 10 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Tango Posted May 7, 2016 Share Posted May 7, 2016 I'm not a fan of using WD-40 on chains.....it's not what it was designed for.Most times I just use a rag to clean the chain......occasionally I use some Muc-off chain cleaner......and use Muc-off ptfe chain lube, which isn't sticky but doesn't fling off onto the rear wheel as much as oil..... Quote Link to comment Share on other sites More sharing options...
Joeman Posted May 7, 2016 Share Posted May 7, 2016 I bought a load of chain lube and cleaner at the excel bike show. It's good stuff, can't remember what it's called though... Useless post I know. Lol Quote Link to comment Share on other sites More sharing options...
Guest Posted May 7, 2016 Share Posted May 7, 2016 I know chains get wet in the rain, but is it safe to blast them with water to dislodge any crap in the chain, as long as you oil/lube after? Quote Link to comment Share on other sites More sharing options...
Guest Posted May 7, 2016 Share Posted May 7, 2016 Anybody wish to share their tehnique? Fit a ScottoilerHoly crap what is this lizardry!? I've just YouTubed this, it looks so simple to install. My only issue would be it only seems to oil the outward facing side/edge of the chain, shouldn't you oil the whole chain? Quote Link to comment Share on other sites More sharing options...
Arwen Posted May 7, 2016 Share Posted May 7, 2016 WD40 Chain cleaner seems to dissolve any grime it touches. I spray some of that on all the chain, leave for a few minutes then go over it with a chain brush (£1 and a 5 weeks wait from ebay!) then wipe it clean with a rag. Quote Link to comment Share on other sites More sharing options...
funinacup Posted May 7, 2016 Share Posted May 7, 2016 Anybody wish to share their tehnique? Fit a ScottoilerHoly crap what is this lizardry!? I've just YouTubed this, it looks so simple to install. My only issue would be it only seems to oil the outward facing side/edge of the chain, shouldn't you oil the whole chain?I'll have one available when I get round to removing it from my bike... Quote Link to comment Share on other sites More sharing options...
Bogof Posted May 7, 2016 Share Posted May 7, 2016 Anybody wish to share their tehnique? Fit a ScottoilerHoly crap what is this lizardry!? I've just YouTubed this, it looks so simple to install. My only issue would be it only seems to oil the outward facing side/edge of the chain, shouldn't you oil the whole chain? You can get one that has an outlet for both sides of the sprocket/chain, but it tends to spread to the other side anyway.Tutoro is almost as good. And cheaper. And currently fitted to my Nelli Quote Link to comment Share on other sites More sharing options...
