Phooey Posted September 20, 2016 Share Posted September 20, 2016 Ok ... for a while now the front brake PULSE when applying. This causes the front to dip and rise. Not too clever when braking hard. There is also a rythmic rubbing sound ... I'm thinking disc runout!MOT passed with no comment on the brake which I thought a little weird. Anyway, I assumed the discs were warped so I got a mate to run his DTI on the rotors. Right disc runout was 3 thou and left disc runout was 2 thou ... Not that then! Calipers are solid with no movement that I can detect.What do I look at next? This is doing my noodle now. Quote Link to comment Share on other sites More sharing options...
TimR Posted September 20, 2016 Share Posted September 20, 2016 Stuck piston Brake disk floating rivets loose Headstock bearings loose Quote Link to comment Share on other sites More sharing options...
Phooey Posted September 20, 2016 Author Share Posted September 20, 2016 Stuck piston Brake disk floating rivets loose Headstock bearings loose All the above fine Tim. Plus the fact, wouldn't any of these highlight on MOT? Especially headstock bearing? Quote Link to comment Share on other sites More sharing options...
Tango Posted September 20, 2016 Share Posted September 20, 2016 Deffo sounds like disk runout.......are you sure you've not got a sticking caliper piston.....and the caliper is floating ok?Wheel bearings ok?As TimR says.....check the disk bobbins are not too loose or sticking....... Quote Link to comment Share on other sites More sharing options...
Phooey Posted September 21, 2016 Author Share Posted September 21, 2016 Deffo sounds like disk runout.......are you sure you've not got a sticking caliper piston.....and the caliper is floating ok?Wheel bearings ok?As TimR says.....check the disk bobbins are not too loose or sticking....... I just ordered a DTI and i'm going to check the runout myself. Bobbins were cleaned a few months ago and are solid. Calipers were re-build when I upgraded them last year.Haven't checked bearings but assumed it wouldnt get through MOT if bearings were gone. Quote Link to comment Share on other sites More sharing options...
eastanglianbiker Posted September 21, 2016 Share Posted September 21, 2016 could it not also be the front tyre mis-shaped or a bulge or weak sidewall of tyre ? Quote Link to comment Share on other sites More sharing options...
Grumpy Old Git Posted September 21, 2016 Share Posted September 21, 2016 Have you got ABS fitted (as part of your 'upgrade')? Quote Link to comment Share on other sites More sharing options...
megawatt Posted September 21, 2016 Share Posted September 21, 2016 Disc is warped. Quote Link to comment Share on other sites More sharing options...
Phooey Posted September 21, 2016 Author Share Posted September 21, 2016 could it not also be the front tyre mis-shaped or a bulge or weak sidewall of tyre ? Brand new Pirelli's mate Quote Link to comment Share on other sites More sharing options...
Phooey Posted September 21, 2016 Author Share Posted September 21, 2016 Have you got ABS fitted (as part of your 'upgrade')? Sadly not GOG. Quote Link to comment Share on other sites More sharing options...
