The return spring is probably broken or detached. What's the bike? Might be an easy fix, depends on whether its inside or outside the crankcase.
They don't have a return spring!
They have a detent spring and a torsion spring!
Firstly remove the gear linkage and check the pivot points aren't seized or sticking this is the most common problem
Ah so it's the description in the Honda parts catalogue that's wrong.http://i.imgur.com/B73cbEi.png
I stand corrected!!
no need to be a bell end about it though :roll:
Correct, I have no need to be a bell end about anything.
Great cheers after looking the diagram I WD40'd the area and left if for an hour and its working fine. Cheers
Sorry forgot to mention that it flicked back up after a few seconds so it wasn't totally broken, anyway thanks
Spot on it would seem Stu!
8-)
Always start with the easiest first and the most common ;-)
Also when you get chance out need to strip and clean the linkage and re grease it otherwise the wd40 will dry out and it will happen again :thumb:
