LegOverLass Posted December 18, 2017 Posted December 18, 2017 Can anyone advise on the bolts needed to mount a sissy bar onto a suzuki intruder vl125 2005?Just received a sissy bar and back wrack. Current bolts aren't long enough and none were provided with the sissy bar though it was supposed to come with Can't be arsed to send it back so does anyone know where i can buy bolts and also spacers if needed? Quote
JRH Posted December 18, 2017 Posted December 18, 2017 Depending on the size could try B&Q, Homebase or screwfix.Then check Amazon and Ebay.There are online suppliers but then postage may be high for just a couple of items. Quote
megawatt Posted December 18, 2017 Posted December 18, 2017 Probably M8 or M6 threads. Measure the depth of the threads and the length of the the mounting tubes in the sissy bar. Try to measure the diameter of the threads.on the bolts you have. When you have all the dimensions, post on here, I may have some spare stainless bolts and washers. Quote
LegOverLass Posted December 18, 2017 Author Posted December 18, 2017 Thanks for the replies. My bolts are M8 and 20mm in length. Sissy bar mount is 5mm.I've found the allan bolts on amazon, not sure about spacers yet. They aren't cheap Quote
Mississippi Bullfrog Posted December 18, 2017 Posted December 18, 2017 You want good quality stainless bolts or they'll rust very quickly. I get my stuff from here http://www.groveco.co.uk/ Quote
megawatt Posted December 18, 2017 Posted December 18, 2017 Never seen spacers for sale, but you could either use loads of stainless washers or buy a length of ally tube with 8mm inside diameter and saw it to length.Have you got an estimate of total length needed, ie tube length plus spacer length plus thread length in frame? Quote
Stu Posted December 18, 2017 Posted December 18, 2017 Never seen spacers for sale, but you could either use loads of stainless washers or buy a length of ally tube with 8mm inside diameter and saw it to length.Have you got an estimate of total length needed, ie tube length plus spacer length plus thread length in frame? Plenty of people sell spacers on eBay and some will even make them to size Quote
TimR Posted December 18, 2017 Posted December 18, 2017 Just contact seller and get some delivered if its meant to come with it then they should foot the bill . Quote
fastbob Posted December 19, 2017 Posted December 19, 2017 Here you go £6.00 for 50 http://i.imgur.com/PAyM4Co.png Quote
LegOverLass Posted January 22, 2018 Author Posted January 22, 2018 Cheers guys, i bought my own while i was waiting for the seller to send some out. Got a few spare now in varying lengths which is just as well as theyre gonna have to be swapped out again to accomodate saddlebag supports aswell now Quote
