MarkW Posted April 22, 2018 Share Posted April 22, 2018 Morning all!I have a hard drive that I removed from a laptop about six years ago after accidentally killing it with a mug of tea. I've been meaning to see if anyone could retrieve the files off it ever since, but as none of them were critical I never got around to it. I've just come across it again in a drawer, and thought I should pull my finger out and get it done.Can anyone recommend a good data retrieval company, and is a light historical poaching in tea likely to pose any problems? Quote Link to comment Share on other sites More sharing options...
MR_W Posted April 22, 2018 Share Posted April 22, 2018 Morning all!I have a hard drive that I removed from a laptop about six years ago after accidentally killing it with a mug of tea. I've been meaning to see if anyone could retrieve the files off it ever since, but as none of them were critical I never got around to it. I've just come across it again in a drawer, and thought I should pull my finger out and get it done.Can anyone recommend a good data retrieval company, and is a light historical poaching in tea likely to pose any problems? If you shut it down straight away it might be fine. Also a date recovery company can be mighty expensive.First thing first, buy yourself a caddy for it and plug it into an existing machine via USB. If it works you just avoided hundreds to thousands of pounds. Quote Link to comment Share on other sites More sharing options...
MarkW Posted April 22, 2018 Author Share Posted April 22, 2018 Cheers buddy, but it's toast unfortunately: I had my brother try it in his drive caddy at the time and he said it needed professional help, so I'm on the hunt for a reputable company that won't break the bank! Quote Link to comment Share on other sites More sharing options...
Moonraker Posted April 22, 2018 Share Posted April 22, 2018 There are companies that can recover information from hard drives that have had some sort of spillage or impact. I recently read about one that handled a hard drive that someone's cat had pee'd on. They're out there but I'm sure they're going to be expensive. It may also only end up as only recovering a percentage of what's on the disk.I can find some companies in LinkedIn and give you their names if you wish? Quote Link to comment Share on other sites More sharing options...
Bender Posted April 22, 2018 Share Posted April 22, 2018 If you can buy exact same model second hand you could try swapping the disk platter into the working drive or swapping the electronics over onto the dead drive which ever is easiest, data recovery is expensive when your down to removing disks from the drive and scanning them, i have swapped control boards over before and that worked but i'm going back 15years at least Quote Link to comment Share on other sites More sharing options...
Via Posted April 22, 2018 Share Posted April 22, 2018 If you can buy exact same model second hand you could try swapping the disk platter into the working drive or swapping the electronics over onto the dead drive which ever is easiest, data recovery is expensive when your down to removing disks from the drive and scanning them, i have swapped control boards over before and that worked but i'm going back 15years at least As this... I'd do electronics though don't touch platters unless you have a sterile roomPlatters should have been sealed and safe against spillage you've just likely trashed electronics Quote Link to comment Share on other sites More sharing options...
Bender Posted April 22, 2018 Share Posted April 22, 2018 errr no i did this 15years ago for a mate, didn't have sterile room, just a cup of tea and a white cloth on the table for when i dropped the screws i could hardly see, drive was already presumed dead, second drive cost 30quid took about 30mins to strip put back together, got drive running, cloned it onto another un touched drive with ghost expanded it into an unmatched drive too if i remember and all was good.lol just re read your post my bad thought you ment i had trashed electronics dohh, yea its prob only control side fooked Quote Link to comment Share on other sites More sharing options...
Via Posted April 22, 2018 Share Posted April 22, 2018 lol just re read your post my bad thought you ment i had trashed electronics dohh, yea its prob only control side fooked Yeah meant OP lolKnow it is doable and have done myself but it is a ticking time bomb as soon as platters exposed to air they are just self destructing and need to get an image off asap... So if can be done another way first always recommend that. Quote Link to comment Share on other sites More sharing options...
MarkW Posted April 22, 2018 Author Share Posted April 22, 2018 As this... I'd do electronics though don't touch platters unless you have a sterile room So what you're saying is that I need to find someone who has done it before, possibly who has a bit of time on his hands but with full use of his fingers, and with access to a sterile working environment like... oh I don't know... say an operating theatre? Quote Link to comment Share on other sites More sharing options...
Via Posted April 22, 2018 Share Posted April 22, 2018 As this... I'd do electronics though don't touch platters unless you have a sterile room So what you're saying is that I need to find someone who has done it before, possibly who has a bit of time on his hands but with full use of his fingers, and with access to a sterile working environment like... oh I don't know... say an operating theatre? Walked right into that one Quote Link to comment Share on other sites More sharing options...
MarkW Posted April 22, 2018 Author Share Posted April 22, 2018 Walked right into that one Or hobbled into it at any rate... So, it's agreed then: I post the knackered drive to you, you take a bad tumble on your next trip to the toilet, and then resurrect the data off it in the operating theatre whilst they're re-pinning your leg. Just PM me the hospital and ward number when you're ready... Quote Link to comment Share on other sites More sharing options...
Bender Posted April 22, 2018 Share Posted April 22, 2018 Don't send it to via it will fetch a whole new meaning to HD crash Ohh and if he does break you won't have a leg to stand on.Sorry couldn't resist edit. Quote Link to comment Share on other sites More sharing options...
Via Posted April 22, 2018 Share Posted April 22, 2018 No words... Quote Link to comment Share on other sites More sharing options...
SlowBusa Posted April 22, 2018 Share Posted April 22, 2018 Have you tried to see if it spins up now?After sitting for so long it might just do it Quote Link to comment Share on other sites More sharing options...
Via Posted April 22, 2018 Share Posted April 22, 2018 Also freezing helps, put in a bag and place in freezer for a bit Quote Link to comment Share on other sites More sharing options...
Stu Posted April 22, 2018 Share Posted April 22, 2018 Also freezing helps, put in a bag and place in freezer for a bit Is that what a morgue is for? Stick you in a bag in a freezer to see if you work again Quote Link to comment Share on other sites More sharing options...
Via Posted April 22, 2018 Share Posted April 22, 2018 Also freezing helps, put in a bag and place in freezer for a bit Is that what a morgue is for? Stick you in a bag in a freezer to see if you work again Lol you guys have a whole thread available to make fun of my stupidity! Quote Link to comment Share on other sites More sharing options...
