Hi
These are the metal things that splay when you tighten the screw. I've remove the screw but the ends are stuck in - any ideas?
Are you sure yours come out?
A lot are solid rubber with a thread inserted in it and designed to stay in
Hi
Oh that's a nice easy one . Put the bolt back in but only screw it in half way , then just give it a little tap with a hammer and the whole thing should come out .
Yes I just removed the weighted oem bar ends and replaced them with these. Now I want to switch back but they seem stuck in, which I get (as the screw forces them outwards) but I wanna know how to remove them
Hi
Legend - thank you!
Ah righty oh then
My next suggestion would have been as [mention]fastbob[/mention] :thumb:
I knew this forum was useful, and more than just butt jokes and biscuit reviews.
Right next one - my throttle sticks open when I tighten my bar end. Which is probably unsafe. Any clues? I can't have it less tight or it'll probably fall off...
sounds like the bar end is catching on the throttle grip
Have a look to see if the throttle tube is extended beyond the handle bar . If it is you could see if you can move it inwards a bit by moving the whole assembly but if there is a locating peg and a little hole in the bars then this may not be possible. The alternative is to strip the whole thing and sand paper a little bit off the end of the throttle tube . Having said all that , have you tried just pushing the grip away from the bar end a bit ? Can we see some pics of this please in order to eliminate the guess work ? Another possibility might be to just move the bar end out a mm or so to stop it rubbing on the grip or the throttle tube .
Surely your not tightening it so much that the handle bar is actually expanding ?
it's definitely touching as when you loosen it again and twist the throttle you see the bar end move :D
It will be inside the grip and not actually at the end
try loosening the throttle housing screws and see if you get any movement away from bar end . most are located on a spigot into the bar but this can give a few mm tolerance .
Sorted! I managed to leave the bar ends a mm out so it didn't touch the throttle tube (I'm learning lots in this process like the grips are glued on etc - I had no idea!) so all good. Thank you all.
Before
After
Sure they look cooler from the side but what I'd failed to appreciate was how much cleaner the view from the saddle is - nothing gets in the way of your vision - so much nicer! They are quite small - I'd perhaps prefer them slightly bigger (I didn't check the size!) but actually compared to the stock mirrors you can probably see more because they clear your body. Haven't ridden with them yet but they appear to be solid - everything works it it should, nice and tight. Would recommend, especially for £19.95 https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F222535871709
Result! Very similar to mine, fitted mine with an M6 bolt straight into the thread. Had to fit a penny washer on the throttle side to allow clearance. Good quality tinted glass and the rest all metal, were about the same price on ebay.
