Ricco1 Posted May 27, 2019 Posted May 27, 2019 I ride an old Yamaha 2 stroke. It runs fine but in heavy rain it cuts out. The solution is to spray wd40 into the spark plug cap, wait a couple of minutes, away it goes. I've replaced the cap and the ht lead but still have the problem. Any ideas? It's a nuisance at best, or potentially dangerous. Quote
raesewell Posted May 27, 2019 Posted May 27, 2019 If WD40 cures the problem then you must have water ingress, double check everything and make sure the plug lead seal properly. Quote
Mississippi Bullfrog Posted May 27, 2019 Posted May 27, 2019 I bet there's a crack in the spark plug insulation. Once water gets in there it's shorting the plug out. I'd try replacing the plug. Quote
megawatt Posted May 27, 2019 Posted May 27, 2019 Be careful spraying WD on sparks. I set my z1000 on fire doing that!!! Quote
Mississippi Bullfrog Posted May 27, 2019 Posted May 27, 2019 or the lead or maybe the cap OP has replaced both the lead and the cap so unless the replacements are faulty it's more likely to be something else. A hairline crack in the spark plug insulation is difficult to see but if water gets in it the electric for the spark will track to earth. Quote
skyrider Posted May 27, 2019 Posted May 27, 2019 yes that will be the first thing to try then change the plug (what model is it) Quote
Stu Posted May 27, 2019 Posted May 27, 2019 fit a fenda extenda to try and reduce the amount of spray and also look for a better plug cap that can seal around the spark plug hole Quote
