Shaun89 Posted August 9, 2019 Share Posted August 9, 2019 Hi, I'm wondering if anyone can give some advice because when it comes to electronics on this bike it's just so complicated. Basically the electrics have gone completely dead I've tested the battery thats fine I've tested power to ignition that's fine but when you turn the key nothing... it's just dead no sounds no lights, I've checked around for loose wires ect everything seems to be intact and everything looks in order I've checked fuse box all fuses are okay, I just cant understand why the bikes showing no sign of life, last time it was running it cut out at traffic lights and all the power just died, any ideas what would just kill the electrics Quote Link to comment Share on other sites More sharing options...
Guest Richzx6r Posted August 10, 2019 Share Posted August 10, 2019 I'd guess you have a short in the barrel maybe? Quote Link to comment Share on other sites More sharing options...
fastbob Posted August 10, 2019 Share Posted August 10, 2019 Check the earth cable for loose bolts or corrosion where it bolts to the frame. Quote Link to comment Share on other sites More sharing options...
Guest Richzx6r Posted August 10, 2019 Share Posted August 10, 2019 Failing that a match Quote Link to comment Share on other sites More sharing options...
fastbob Posted August 10, 2019 Share Posted August 10, 2019 Failing that a match Why would you say that ? Quote Link to comment Share on other sites More sharing options...
Guest Richzx6r Posted August 10, 2019 Share Posted August 10, 2019 Can claim on the insurance and replace it, would be easier than playing with magic and wizardry Quote Link to comment Share on other sites More sharing options...
fastbob Posted August 10, 2019 Share Posted August 10, 2019 Can claim on the insurance and replace it, would be easier than playing with magic and wizardry Rich , give it a rest mate , this is not very helpful . Quote Link to comment Share on other sites More sharing options...
sm0129 Posted August 10, 2019 Share Posted August 10, 2019 Buy yourself a cheap multi meter and watch some youtube vids. hopefully you will be able to trace the fault.As said above, check the earth as they cause the majority of electric problems Quote Link to comment Share on other sites More sharing options...
skyrider Posted August 10, 2019 Share Posted August 10, 2019 or check the connectors on the battery Quote Link to comment Share on other sites More sharing options...
Grumpy Old Git Posted August 11, 2019 Share Posted August 11, 2019 You don't even need a multimeter - Use a 12v bulb or horn; ground one terminal and touch the other to the 'input' to the main fuse. If nothing, then the issue is back from there, through the ignition switch. Not a lot of wire to trace.However, if that is not the problem (you have power at (and through) the main fuse, then you will need a voltmeter to trace the fault. Quote Link to comment Share on other sites More sharing options...
fastbob Posted August 11, 2019 Share Posted August 11, 2019 I've actually traced electrical problems in the past by placing the bike in total darkness and having a good fiddle around until I see a spark ! Not very scientific but whatever works . Quote Link to comment Share on other sites More sharing options...
