Hi guy's, I have a lexmoto titan 125cc and went out to work on Friday and when I come home I went to go the shop and the battery was flat so I baight a brand new battery from Halford I fitted it and there was still no power so I took it to a garage and the negative terminal was broke so it got replaced along with a fuse and it worked perfect started first push on button.... Now today I went to start it up and there is no power again but there's a brand new battery and terminal fitted few days ago. Can anybody help me as I don't know why the ignition wont come on wen it was working perfectly the day before pleaseeee help thanks guys
Sounds like our resident Chinese motorcycle specialist [mention]fastbob[/mention] is needed!
Would you agree [mention]Six30[/mention]
Ok, so let’s assume there is an earth leakage that drained the original battery, the same thing is going to happen to the new battery.
If you have a multimeter take off the earth connection, put the multimeter across from the earth terminal to the bike frame and set it to milliamperes. It ought to read very low if anything. A few Milliamps maybe but nothing significant.
If there is a drain pull the fuses until it stops, that will help narrow it down.
Sounds like our resident Chinese motorcycle specialist @fastbob is needed!
Would you agree @Six30
bobs on cougar duties, tied up at the minute..... literally.
Guest Richzx6r
I'd say that the magic has disappeared from a wire somewhere, I'd suggest contacting your local wizard for a spell
Just check all electrical connections and fuses including the feed from the alternator to the rectifier regulator , Clean and tighten as necessary . If you don't find anything obviously wrong , buy a multimeter from Wilko ( £13.00 ) and perform some diagnostic tests in accordance with your workshop manual . Sorry , that last bit was a little tongue in cheek because I doubt that there is a manual for your bike . Alternatively , take it back to the jokers at this garage and tell them that they have not fixed the problem .
Sounds like your main fuse has gone again if theres no ignition, would do as [mention]Mississippi Bullfrog[/mention] says , and get yourself one of these manuals, they are all pretty much generic, so worth it if your keeping the scooter
https://www.ebay.co.uk/itm/Chinese-Scooter-Manual-Haynes-XOR-50-125-Ideo-50-Cracker-50-Evolution-50-HB4768/151326890708?hash=item233bc91ad4:g:wy0AAOSw4CFY4i1F
