V650 Posted July 7, 2024 Posted July 7, 2024 Got up early and and cleaned the bike Waxed and ready to go but as I was putting away the cleaning gear the rain came down So back on with the cover Maybe next week 4 Quote
Mickly Posted July 7, 2024 Posted July 7, 2024 On 06/07/2024 at 08:03, RideWithStyles said: Feel for you experience and knowledge says Safety glasses and cut resistant gloves, Arco, b&m and screwfix sell them cheap. Packs of 5 to 10s for under a £10. Worst thing is that I actually have an equivalent pair that I did think I needed to wear 1 Quote
Bianco2564 Posted July 7, 2024 Posted July 7, 2024 Got the gearbox out this afternoon, such a doddle with the cassette gearbox compared to a conventional set up. Will replace the input shaft bearings, the one in the crankcase does feel a bit rough. 8 Quote
Bianco2564 Posted July 8, 2024 Posted July 8, 2024 Got the bearings out of the crankcase, the smaller one is in a blind bore so borrowed a bearing puller from work. A little blast with the heat gun and it came straight out. Removed the output shaft seal housing, another hit with the heat gun and a couple of taps with a hammer and drift had him out. Will tackle the two in the gear cluster tomorrow night. 6 Quote
AstronautNinja Posted July 9, 2024 Posted July 9, 2024 Ordered a few bits....... Sat with my helmet on for an hour or so to make sure its comfy before my opportunity to return it passes, very happy with it. 2 Quote
Simon Davey Posted July 9, 2024 Posted July 9, 2024 (edited) 4 minutes ago, AstronautNinja said: Ordered a few bits....... Sat with my helmet on for an hour or so to make sure its comfy before my opportunity to return it passes, very happy with it. Did you buy it in store? Is it tight? Because it will be give a fair bit. You need to make sure you can't move it around at all, your cheeks need to be a bit squashed, but not uncomfortable. I came back to biking and wasted money on a helmet that the guy in the shop said fitted perfectly, it turned out to be way too big. Edited July 9, 2024 by Simon Davey Quote
AstronautNinja Posted July 9, 2024 Posted July 9, 2024 2 hours ago, Simon Davey said: Did you buy it in store? Is it tight? Because it will be give a fair bit. You need to make sure you can't move it around at all, your cheeks need to be a bit squashed, but not uncomfortable. I came back to biking and wasted money on a helmet that the guy in the shop said fitted perfectly, it turned out to be way too big. No I bought it online but have had helmets in the past including quite a few mountain bike full face so knew how things should be. I'm happy with it, especially the pin lock internal visor. I don't know when they were invented but they work amazingly. No amount of my sex offender breathing manages to fog it up 2 Quote
RideWithStyles Posted July 9, 2024 Posted July 9, 2024 A very long time ago, legend has it that it was invented for such people by those people . I’m a fan of pinlocks! Avoid touching it and or rubbing it, especially when wet! clean both sides with running water only, shake off excess water and leave to dry naturally. 1 Quote
AstronautNinja Posted July 9, 2024 Posted July 9, 2024 58 minutes ago, RideWithStyles said: A very long time ago, legend has it that it was invented for such people by those people . I’m a fan of pinlocks! Avoid touching it and or rubbing it, especially when wet! clean both sides with running water only, shake off excess water and leave to dry naturally. It did seem weird the helmet arrived with long tatty hair and a stick on cigar. 1 1 Quote
Bianco2564 Posted July 9, 2024 Posted July 9, 2024 The final stage of the strip down, gear clusters pushed out and removed both bearings. The smaller bearing on the input shaft and the main output shaft bearing sound rough. Got the card out and ordered 4 new bearings and gaskets from The Tuning Works, an RGV specialist supplier. 7 Quote
Simon Davey Posted July 9, 2024 Posted July 9, 2024 55 minutes ago, Bianco2564 said: The final stage of the strip down, gear clusters pushed out and removed both bearings. The smaller bearing on the input shaft and the main output shaft bearing sound rough. Got the card out and ordered 4 new bearings and gaskets from The Tuning Works, an RGV specialist supplier. I don't know what I'm more impressed with.... You having the bottle to strip your gearbox, or, actually being able to remember how it all goes back together. 1 Quote
Bianco2564 Posted July 9, 2024 Posted July 9, 2024 1 hour ago, Simon Davey said: I don't know what I'm more impressed with.... You having the bottle to strip your gearbox, or, actually being able to remember how it all goes back together. Thanks. Ive owned the RGV for 11 years now, bought as a box of bits and had to assemble the engine from parts. I’ve had it apart a couple of times since, replaced the crank, pistons and had the barrels replated and another time to replace the gearbox output shaft. Lots of photos help when stripping stuff like this, keeping it laid out in order, a compartmented box for fasteners and widgets and of course a workshop manual, genuine Suzuki in this case. 2 1 Quote
Ian Frog Posted July 10, 2024 Posted July 10, 2024 Took the little 125 for it's 1st MOT since 2018 passed with no advisories. Probably put it up for sale after my holiday so if anyone knows of someone looking for a non chinese 125 let me know. Cheers Ian 5 Quote
Ian Frog Posted July 10, 2024 Posted July 10, 2024 Put the Beemer up on the lift for the first time and just realised she's a big girl lol. Cheers Ian 2 1 Quote
Ian Frog Posted July 10, 2024 Posted July 10, 2024 For context the Indian normally resides on the lift and takes a lot less shoving to move lol. Cheers Ian Quote
AstronautNinja Posted July 10, 2024 Posted July 10, 2024 20 minutes ago, Ian Frog said: For context the Indian normally resides on the lift and takes a lot less shoving to move lol. Cheers Ian Did they run out of office chairs in the call center? 2 Quote
AstronautNinja Posted July 10, 2024 Posted July 10, 2024 I started off, before I got distracted, intending to ask @Ian Frog how / where that lift connects / rests? Never seen one before. Quote
AstronautNinja Posted July 10, 2024 Posted July 10, 2024 And before any possible incoming ban hammer swings my way it took a genuine 30 seconds+ as a car guy to remember an Indian was a manufacturer and not some poor chap he had locked up in his garage. Apologies if we don't find said stupidity funny 2 2 Quote
Ian Frog Posted July 10, 2024 Posted July 10, 2024 Just google Abbastands you won't look back. Cheers Ian Quote
Simon Davey Posted July 10, 2024 Posted July 10, 2024 1 minute ago, Ian Frog said: said Indian lol cheers Ian That's a stunner, is it stock? Quote
Ian Frog Posted July 10, 2024 Posted July 10, 2024 At the moment! Nice thing about the FTR Carbon is you can turn everything off. Cheers Ian 1 Quote
AstronautNinja Posted July 10, 2024 Posted July 10, 2024 24 minutes ago, Ian Frog said: Just google Abbastands you won't look back. Cheers Ian Where do they attatch / rest on? I can't quite s tell....... They look immense. 21 minutes ago, Ian Frog said: said Indian lol cheers Ian That's cool AF 1 Quote
Ian Frog Posted July 11, 2024 Posted July 11, 2024 The Abba stands connect at the swing arm pivot allowing many different bikes to be lifted by having different connecting bobbins available for different bikes. They don`t have to be horizontal either lol. Cheers Ian 1 Quote
