Fish Posted September 11, 2020 Posted September 11, 2020 So what's the better option, laser or metal rod attachment?ThanksFish Quote
Guest Richzx6r Posted September 11, 2020 Posted September 11, 2020 I'd guess laser as it cant get bent, I just use luck and some eye line, give the wheel a quick spin and see if its catching on the sprockets or not it not I'd surmise it's good Quote
Mississippi Bullfrog Posted September 11, 2020 Posted September 11, 2020 So often it depends more on how the device attaches. I just do it by eye and so far the sky hasn't fallen down. I reckon some of the gadgets are mainly to pander to those suckers like me who like buying tools. Quote
Tiggie Posted September 11, 2020 Posted September 11, 2020 [mention]Mississippi Bullfrog[/mention] Quote
TimR Posted September 12, 2020 Posted September 12, 2020 I bought the lazer monkey from tru tension a while ago as a aid for my wife to adjust her own chainToo many variables ....It has to sit on the sprocket true and it only clamps by two bits of plastics under compression tension .There are mutiple hinged points that have some free play in so can give a false reading . You potentially have to remove items to use it ie chain guard .The batteries supplied are for testing only and last about 30 secs. You have to manually move the laset head again on a hinge that will sway and alter the placement....So in my opinion its crap but it can be used as a check tool after doing it manually ie string methodDid think about getting the magnet laser style but how does it determine if your chain sits deep enough for the laser height etc Quote
megawatt Posted September 12, 2020 Posted September 12, 2020 I just measure the distance apart of the spindle centres on both sides. Seems to work. Quote
Fish Posted September 14, 2020 Author Posted September 14, 2020 I just measure the distance apart of the spindle centres on both sides. Seems to work. Sadly the exhaust is in the way on the offside. Off to buy a sprocket laser (also love a gadget).Fish Quote
xMachina Posted September 14, 2020 Posted September 14, 2020 I've got a laser monkey too, I also think its a bit pants. Worked great on my WR125 and I was really impressed by it, however on both the Bandit and the Gixxer it's totally useless. It never seems to want to stay put, and as TimR mentioned, the moment you move the laser bit it shifts and you have to start again. It's frustrating as I got great results with it previously, I think it really depends on your sprocket type. Quote
