I have made some changes to the streams!
I have tried to make these as close as I can to how they used to work
I will do a guide on how they work and how to change them etc
But essentially I have changed the default stream to unread which corresponds the the buttons on the mobile version arrowed below
These two buttons arrowed will take you to unread posts unless you create your own stream and set it as default then this will override that button
PS on mobile for active topics you will have to click the three line menu button in the top right then click active
1 hour ago, Bender said:
There are no new posts, cmon folk get posting 😂
Some of us have a life @Bender 🤣🤣:seeya:
Guest Swagman
There you go.
Just now, James in Brum said:
I don’t know if it is my furtling or yours @Stubut I can use the forum again! Thank you.
Possibly a mixture of both
Did you read the guide I put on about streams?
I did and it did not quite do what I wanted when I tried. I kept trying but was getting it wonky I think. I now have exactly what I want. Basically the same as the active topics button on the ones one.
making sure I read all new posts is a delightful part of my Dadmin.
When you press whichever button you press what does it say the stream is?
1 hour ago, James in Brum said:
Cool, either way I am happy to find it useable again.
It's just time, there was such a step change it was like a different world.
It's starting to look and work a bit more like the old place now.
how do you delete a post now, was meant to quote someone  but posted as just a reply by mistake.
Not sure you're ever allowed to delete posts on most forums, only edit?
could do on old system, if you done it just after you posted.
There was a time limit on deleting I will see if I can add it here
But you  could just edit the post and add the quote!
