Battery Charger for multiple bikes
Ohrammer
Im bloody lucky to have more than one bike however I seem to spend more and more time either charging, jumping or replacing batteries before I can go and play. Is there a multiple battery charger and if there are which ones Is the best
I have two bikes and use a couple of CTEK chargers to maintain the batteries. I've not seen a charger for multiple batteries but it would need to monitor each battery separately so in effect you'd have multiple chargers just in one unit. So I'd stick with the simpler option of separate chargers. That way if one breaks it's just the one, you haven't lost the lot.
Bikes should not need constant charging IMHO.
I have 2 bikes and no charging, in the garage, however if needed I can charge at work.  10 hours once a month seems to be enough, or 10 hours every 2 weeks for the one with an alarm if not used otherwise.
An hours ride is enough to keep the battery topped up.
If you have power in the garage you can get fly leads to connect each bike easily enough.
If you want to charge 24/7 why not do week and week about, even with 3 bikes that should be fine.  I would start bike before charging just so you know the battery has the umph to do it.
