Mississippi Bullfrog Posted April 24, 2023 Posted April 24, 2023 I need new tyres and would prefer to be able to change them myself. Those who do their own tyres, what tools do you use? Any types of levers better than others? Thanks. Quote
Bender Posted April 24, 2023 Posted April 24, 2023 53 minutes ago, Mississippi Bullfrog said: I need new tyres and would prefer to be able to change them myself. Those who do their own tyres, what tools do you use? Any types of levers better than others? Thanks. Don't forget the balancing, plenty of vids on YouTube Quote
Fiddlesticks Posted April 24, 2023 Posted April 24, 2023 (edited) My setup.. Amazon - BTSKY Tire Levers Spoon Set of 3 Amazon - Johiux 44pcs Valve Core Remover Tool Amazon - Haskyy 7 Wheel weights BLACK 12x5g Ebay - Tyre bay direct black tyre bead paste - 5kg Ebay - Qtech Motorcycle Motorbike Static WHEEL BALANCER Portable STAND Ebay - TRIUMPH STATIC WHEEL BALANCER ADAPTER FOR TIGER EXPLORER & ROCKET 3 (extra large cones needed as back wheel attaches to single sided swing arm and has a large hub) Screwfix - Titan TTB797CPR 24Ltr Electric Oil-Free Air Compressor with 5 Piece Accessory Kit (got a bit of stick on here for that one, but it works fine, just got to remember to leave the drain plug out) - also got a quick release kit for this to swap out the tools easily. It's also handy for applying XCP /ACF50 and other little jobs. Wife - Hairdryer (don't tell her) Using the spoons takes technique and force, but as with everything there's youtube. Tried everything, including the local petrol station airline before getting the compressor, nothing worked. Edited April 24, 2023 by Fiddlesticks 1 1 Quote
Fiddlesticks Posted April 24, 2023 Posted April 24, 2023 Have also mucked about with cable ties and g clamps without much success. Hmm. That sounds much ruder than intended. Quote
Stu Posted April 24, 2023 Posted April 24, 2023 I use one of these but with a different bar that doesn't mark the wheels https://www.ebay.co.uk/itm/295426931943?var=0&mkevt=1&mkcid=1&mkrid=710-53481-19255-0&campid=5338268676&toolid=10044&customid=CjwKCAjw0ZiiBhBKEiwA4PT9z6VooHxJ2Du87T19Qcn_BbuCw0NghnYzxQKYL_2kJzmE5Yf68ACoHBoCmJYQAvD_BwE 1 1 Quote
Mississippi Bullfrog Posted April 25, 2023 Author Posted April 25, 2023 11 hours ago, Stu said: I use one of these but with a different bar that doesn't mark the wheels https://www.ebay.co.uk/itm/295426931943?var=0&mkevt=1&mkcid=1&mkrid=710-53481-19255-0&campid=5338268676&toolid=10044&customid=CjwKCAjw0ZiiBhBKEiwA4PT9z6VooHxJ2Du87T19Qcn_BbuCw0NghnYzxQKYL_2kJzmE5Yf68ACoHBoCmJYQAvD_BwE I am a bit of a sucker when it comes to tools. I have acquired all sorts of stuff over the years and that bit of kit is currently on a good discount. However, in a couple of years I hope to retire which means moving to a smaller house with less garage space. So I need something that doesn't take up too much space. In the past I've bought Motion Pro stuff only to find it's made in China. Their bead breaker levers that sell for £75 are very similar to ebay tools at £25. Quote
Stu Posted April 25, 2023 Posted April 25, 2023 1 minute ago, Mississippi Bullfrog said: I am a bit of a sucker when it comes to tools. I have acquired all sorts of stuff over the years and that bit of kit is currently on a good discount. However, in a couple of years I hope to retire which means moving to a smaller house with less garage space. So I need something that doesn't take up too much space. In the past I've bought Motion Pro stuff only to find it's made in China. Their bead breaker levers that sell for £75 are very similar to ebay tools at £25. Mine sits snugly in a corner until I use it and it bolts on to the floor when needed No hassle putting it in place and bolting it down I use a 4 bolts of the type where you insert a sleeve with the bolt and the sleeve stays in place so it's a matter of just popping the 4 bolts in the holes and I use an electric impact gun to just literally nip them up job done Quote
husoi Posted April 25, 2023 Posted April 25, 2023 You would have to pay £10 each wheel. The cost of tools plus the time you will spend doing it makes me wonder if it is worth the trouble. Quote
Mississippi Bullfrog Posted April 25, 2023 Author Posted April 25, 2023 6 hours ago, husoi said: You would have to pay £10 each wheel. The cost of tools plus the time you will spend doing it makes me wonder if it is worth the trouble. To be honest I'd prefer to do it myself. And it saves the hassle I've had ringing round and then people never getting back to me. And HMRC owe me £500. 1 Quote
Stu Posted April 25, 2023 Posted April 25, 2023 8 hours ago, husoi said: You would have to pay £10 each wheel. The cost of tools plus the time you will spend doing it makes me wonder if it is worth the trouble. One place bent my disc's costing my £350 so on that basis alone yes its worth it Also the amount of tyres I have changed its paid for itself and the time it takes to mess about getting the wheels and tyres to somewhere that can change them I could have changed them in 30 mins max Quote
